I just made arrangements to purchase a 2003 Mule 3010 4x4, but I cannot locate the VIN.
I'm sure the Owner's Manual tells me where to look, but of course, the owner misplaced the manual. Can anyone point me in the right direction? I also looked at the Kawasaki website about ordering an owner's manual, but I believe I should have the VIN to make sure I order the correct manual plus any supplements. Thanks in advance. |
#4 (permalink) |
Thanks, Harry, that sounds like the most likely spot, but I crawled all over that Mule and still can't locate a VIN plate, nor can I spot an area where a plate might have been, if one had been removed.
I'll solicit someone else's help, because I just might be blind. Thanks again for your reply which was helpful and encouraging. |
#5 (permalink) |
My owners manual indicates that the frame number and engine number are used to register the mule. The frame number is below the front of the seat and the engine number is on the top of the engine. The decal with the year and model number is on the seat frame and is visible when the seat is raised.
The Kaw website indicates the following for the other Mules: You will find the VIN on your Kawasaki utility vehicle stamped into the frame front cross member between the front wheels of the MULE 520 and 550, or on the right side frame tube just behind the radiator grill at the front of the MULE 2500, 2510, and 2520. Last edited by usnavyvet : 11-02-2006 at 03:28 PM. |
| mule 3010 oil in air filter problems | cody25 | Kawasaki ATV and Mule | 20 | 03-18-2009 12:55 PM |
| More power for mule 3010 4x4 | JSC | Kawasaki ATV and Mule | 6 | 08-31-2008 11:51 PM |
| How can I make my Mule 3010 gas 4x4 go faster? | shadownet_42 | Kawasaki ATV and Mule | 6 | 10-04-2006 05:28 AM |
| need mule 3010 help | PATRON 3010 | Kawasaki ATV and Mule | 3 | 09-19-2006 09:55 PM |
| Kawasaki 3010 Diesel Mule | singlecopy | Kawasaki ATV and Mule | 2 | 01-06-2006 06:37 PM |
