Gas smell in the oil 3010
+ Reply to Thread
Results 1 to 5 of 5
Thread: Gas smell in the oil 3010
  1. #1
    Third Gear And Gaining BTK Intermediate
    Join Date
    Dec 2005
    Posts
    136
    Default Gas smell in the oil 3010
    I think I read this on here before, but can't find it. It seems there's a gas smell on my oil dip stick. How does this happen? Could be be from leaving the choke on to long? Help if you can Thanks
    Mick
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Join Date
    Oct 2006
    Posts
    15
    4 weeks and no answer? I'll try...
    There is another post regarding this and the most logical answer that I recall from it was that the carb was not seated properly or loose. Worth checking anyway.
    I can tell you that it is not normal.
  4. #3
    Join Date
    Sep 2006
    Posts
    34
    dont know much about mules but it sounds like your return line is cloged or something ( sending gas stright into the engine un burned insted of sending it back to the tank) this prevent flooding. change your oil because the gas just wrecked it and the oil is no good.
  5. #4
    Join Date
    Sep 2005
    Location
    Oklahoma
    Posts
    32
    The main reason we see fuel in the oil is when the mule is not fully warmed up and is used for a lot of stop and go. We have dog kennels around here and the start, move 10 feet and turn off kills these motors.
    What I would recomend is change the oil asap as stated above. Then try to ensure that the mule is fully warmed up at the beginning of the day, that should stop the wash of the cylinders and the extra gas getting into your oil..
    Hope this helps.
    Jon
  6. #5
    Join Date
    Dec 2005
    Posts
    136
    Thank you for all your help, I've changed the oil and make sure now that it is warmed up before taking off and using little of the choke. Thanks again. Always good advise from the people on this site
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. men's rules for women - wouldn't let the wife see
    By Freakinout in forum Off Topic
    Last Post: 09-29-2010, 03:08 PM
  2. in the mail - Vulcan 2000 Oil Level Check Procedure
    By Spok in forum Kawasaki Cruisers
    Last Post: 11-05-2008, 11:19 AM
  3. 3010 Mule gas in oil
    By workmule in forum Kawasaki ATV and Mule
    Last Post: 04-04-2005, 03:54 PM
  4. another meanie prob..gas smell on oil cap
    By jace7124 in forum Kawasaki Cruisers
    Last Post: 03-21-2005, 08:59 AM
  5. Getting Gas into the Oil???
    By mazdawg1987 in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 07-27-2004, 04:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
