Old 04-03-2007   #1 (permalink)
Harry Balzac
Default Update on Coolant in Oil Problem
I finally got the water pump for the Mule 2500 that had the severe coolant in the crankcase issue. I replaced the pump and gaskets and the problem went away. That's two different Mules with the same problem in two weeks. Wierd. Oh, and the reason I didn't see any coolant out the pump's weephole is because the weephole was clogged.
Harry Balzac is offline   Reply With Quote
Old 06-12-2007   #2 (permalink)
rg500
Default engine smokes
Hi, with the 2 mules u diagnosed and fixed, did their engines smoke (white smoke), indicating water leaking in the cylinders? Tx.
rg500 is offline   Reply With Quote
Old 06-12-2007   #3 (permalink)
Harry Balzac
Not that I recall. The only symptom I remember is the frothy pink oil, and low coolant.
zx750h Coolant problem *Help please!* garfunkel Kawasaki Streetbikes/Sportbikes 4 06-02-2006 08:29 PM
What brand and type of engine oil are you using? uf-engineer Kawasaki Cruisers 40 03-07-2006 10:20 PM
Oil Light Problem..Please help....! STU The Mechanics Corner 2 09-16-2005 10:25 AM
Coolant in oil. But head and gasket look fine. zx60087 The Mechanics Corner 5 06-13-2005 09:06 PM
What's the best oil? duckfan The Mechanics Corner 33 01-22-2005 10:21 PM
