Jedi master
Do you mean a relay or a selanoid? It is definately not a selanoid, the wires are too small and they. It kind of looks like a fuse(I dont know that it is though). Where do the wires lead to?
'03 YZ250 '03 Kodiak 400 '05 YFZ450 I turned blue! Last edited by YurFatMom : 04-06-2007 at 05:20 PM. |
#6 (permalink) |
Shadetree Mech
Yes it is the starter relay, the greenish wire is neut. switch 12 v. and the brown is ign. 12 v. one blk is starter button and other is starter solinoid.
"I can fix anything......except stupidity" 1981 C B 750 Custom 1989 Bayou KLF 300 c 4x4 |
#7 (permalink) |
Never quite fixed.
I don't mean to thread jack, but how would I go about wiring up a new non-OEM starter relay utilizing the stock switch? I tried just bypassing it, but then I got no spark, the stock wiring is pretty trashed, and I don't know where to start. I already have the relay wired up, all it needs is a switch and battery.
Does this relay actually connect right to the starter? |
#8 (permalink) |
Shadetree Mech
"how would I go about wiring up a new non-OEM starter relay utilizing the stock switch?
I already have the relay wired up, all it needs is a switch and battery." What excactly do you need ? If you allready have a relay wired in "Does this relay actually connect right to the starter?" No not directly to the starter but it does to the solinoid
#9 (permalink) | |
Never quite fixed.
#11 (permalink) |
Shadetree Mech
The relay is primarily there for safty reasons. you must have it in neut. to start. The brown wire (ign 12 v.). the green wire activates the relay when the trans is (neut switch) in neutral, which allows current to go from the start button to the solinoid. Other small wire on the sol. grnds. out allowing current to flow across the bat/starter wires.
#15 (permalink) | |
Shadetree Mech
It will still be cheaper than replacing some of that high dollar ign.....and you get good clean wire and connections.
"I can fix anything......except stupidity" 1981 C B 750 Custom 1989 Bayou KLF 300 c 4x4 Last edited by fb0226 : 11-19-2008 at 07:56 PM. |
#16 (permalink) | |
Way Too Much Free Time
| Bayou 220 - Help with Hoses | TAQuickness | Kawasaki ATV and Mule | 6 | 01-16-2007 11:12 AM |
| Bayou 220 Spit and sputtering | Bayou Nut | Kawasaki ATV and Mule | 8 | 10-10-2006 12:26 AM |
| KLF 220 Bayou Shifting problem | KLF@@) | Kawasaki ATV and Mule | 1 | 09-10-2006 08:22 PM |
| 1988 bayou 220 cc timing | spydiweb | Kawasaki ATV and Mule | 2 | 09-08-2006 10:13 PM |
| trouble with my 220 bayou 1988 | barri35 | Kawasaki ATV and Mule | 2 | 11-14-2004 10:20 AM |
