Old 06-08-2007   #1 (permalink)
Toddbo34
Default '03 Prarie 650 Backfire
My '03 Prarie 650 battery went dead the other day when my son left the key on. I had to jump it with the battery charger to get it going. It's still weak but will start it. Evey since that happened it backfires and won't go over 8 mph. I need any advice that's out there. I drained the fuel, changed the spark plugs and checked the air filter. I'm lost now!! HELP!!!
Toddbo34 is offline   Reply With Quote
Old 06-08-2007   #2 (permalink)
Mercury
Mercury's Avatar
Send a message via AIM to Mercury
is the belt light on and what does the display say? Sounds like its in limp mode and theres a way to reset that - check your book
I have a 360 and theres a method to clear any belt faults
kenny
2000 drifter 800 - lightly modded
2003 360 4x4 atv
Mercury is offline   Reply With Quote
Old 06-09-2007   #3 (permalink)
Toddbo34
How many hours should a belt last under normal use? The belt light came on at 100 hours and i never reset it. Now it has 184 hours on it. The dealer is telling me the belt needs to be adjusted or replaced. What's your opinion?
The only lights on are the belt light.
Old 06-09-2007   #4 (permalink)
Mercury
Mercury's Avatar
my opinion is reset the belt light, it should make it go fast again, if the belt light comes on yet again in very short time, then go get it checked out
kenny
2003 360 4x4 atv
Old 06-12-2007   #5 (permalink)
Toddbo34
Default How
How do you reset the belt light?
Old 06-12-2007   #6 (permalink)
Mercury
Mercury's Avatar
I know how to do it on my 360, the 650 may be different
if youre going to do your own work i would go get a manual, about 40-60 bux from the dealer
OR ask the dealer how to clear the light
on MINE: theres two plugs, one is black other is white, you ign off and swap them, then ign on - light blinks 7 times, then ign off and put it back then run as normal
something like that anyway - im going from memory
kenny
2003 360 4x4 atv
2003 Prarie 650 Question..... matt_aggie04 Kawasaki ATV and Mule 0 02-11-2007 10:15 PM
Prarie 650 Idle Adjustment abelgus Kawasaki ATV and Mule 0 11-15-2006 06:43 PM
Prarie 650 gauge pod denzdye Kawasaki ATV and Mule 0 07-06-2006 10:42 AM
Prarie 650 New Rear Tire Size? NovaPwr Kawasaki ATV and Mule 2 01-06-2006 10:00 AM
Prarie 650 New Rear Tire Size? NovaPwr Kawasaki Motocross and Offroad 4 12-20-2005 02:55 PM
