Old 06-13-2007   #1 (permalink)
Kawacowboy
Unhappy Choked to death Bayou
I have a '94 Bayou 300 that absolutely will not start if the choke is used at all, no matter what the temperature is. I have to pull the spark plug and "air out" the cylinder before I can get it to start. I bought it from a friend who gave me this instruction: "Don't ever, and I mean ever, use the choke. You'll never get it to start if you do!" Any comments on what, if anything, I should do?
Kawacowboy is offline   Reply With Quote
Old 06-13-2007   #2 (permalink)
YurFatMom
Jedi master
YurFatMom's Avatar
Well, it is definately getting too much gas. I would suggest adjusting the fuel screw leaner(in) 1/8 of a turn at a time to clean things up.
'03 YZ250
'03 Kodiak 400
'05 YFZ450
I turned blue!
YurFatMom is offline   Reply With Quote
Old 06-13-2007   #3 (permalink)
Kawacowboy
I forgot to mention that the previous owner took it in to the dealer every year for a checkout and tuneup.
Old 06-13-2007   #4 (permalink)
YurFatMom
Jedi master
YurFatMom's Avatar
I hold steady on my statement.
'03 YZ250
'03 Kodiak 400
'05 YFZ450
I turned blue!
Old 06-14-2007   #5 (permalink)
Trail Buster
Check the choke circuit in the carb. If it uses a richening system, something is leaking or stuck open. If a butterfly valve at the carb opening, it's stuck shut. Grease your cable if you got one.
Trail Buster is offline   Reply With Quote
Old 06-14-2007   #6 (permalink)
YurFatMom
Jedi master
YurFatMom's Avatar
Well, if it gets worse when you turn the choke on, that probably isnt the problem. And a butterfly valve deffinately isnt stuck, because the bike runs fine above idle.
It could also be that the float needle isnt completly sealing, and when it sits, it slowly overflows and fills the cylinder up with fuel.
'03 YZ250
'03 Kodiak 400
'05 YFZ450
I turned blue!
bayou 220 stator, pre-1996 trade/buy read! farmereinar Accessory Swap Meet 3 06-17-2009 06:00 AM
Bayou 300 CDI, Regulator, & Carb SteveS Offroad Buy/Sell/Trade 2 05-16-2008 11:20 PM
Bayou 250 (2x4) A1, A2 and A3 Differences WVHunter129 Kawasaki ATV and Mule 1 02-14-2007 02:31 AM
Replacement starter relay/solenoid therealSnafoo The Mechanics Corner 13 04-04-2006 10:02 AM
On Death Row..... neebelung Off Topic 25 11-23-2005 10:14 AM
