Old 06-14-2007   #1 (permalink)
lakesidemule
Default mule thermostat location?
hi-
i have an older 2510 gasser mule. i would like to change out the old thermostat as i suspect it may have failed/be failing. no temp guage, but after short driving, an anti-freeze smelling cloud follows me! have owners manual, but no maintenance manual.
thanks in advance....... lakeside
lakesidemule is offline   Reply With Quote
Old 06-14-2007   #2 (permalink)
Harry Balzac
The thermostat is on the rear cylinder head on the right side of the engine. The thermostat housing has a large black hose coming out of it; I think the metal tube the follows the hose has the bleeder screw on it.
By the was check the weep hole at the base of the water pump. It is located on the left side of the engine near the front cylinder head. Its partly hidden by the inner converter cover. A failing thermostat probably won't cause a leak , so I'd suggest looking for loose clamps, gaskets, etc.
Harry Balzac is offline   Reply With Quote
Getty Up Mule Speed Kit Review mattm Kawasaki ATV and Mule 12 09-19-2007 03:15 AM
1988 Mule Idles rough & Beeps over 15 MPH GS_Adventure Kawasaki ATV and Mule 6 05-14-2007 11:16 PM
Mule 2010...possible? johnnyb315 Kawasaki ATV and Mule 0 09-26-2006 11:58 PM
having trouble with my mule boltzojoe2 Kawasaki ATV and Mule 8 06-12-2006 04:09 PM
mule vin location cajunblood Kawasaki ATV and Mule 2 07-02-2005 06:09 PM
