Old 07-15-2007   #1 (permalink)
maxr78
Default Help 220 bayou carb problems
I took the carb out to clean it and when I put it back in the throttle won't work and it will only start for 1 or 2 sec. and die.
maxr78 is offline   Reply With Quote
Old 11-13-2007   #2 (permalink)
gtp34934
Send a message via AIM to gtp34934
i think its possible to put the slide back in wrong, sometimes theres a tab to direct it in the right way, you might wanna check that
gtp34934 is offline   Reply With Quote
Bayou 300 carb problems antiqucycle Kawasaki ATV and Mule 102 1 Day Ago 10:37 PM
kawasaki bayou 220 starter problems... ChadD The Mechanics Corner 8 10-21-2008 08:07 PM
98 Bayou 220 Problems! exrider1 Kawasaki ATV and Mule 3 12-28-2006 03:58 AM
Bayou 220 carb adjust help needed jhall The Mechanics Corner 4 04-01-2006 11:30 PM
Bayou 220 carb adjust help needed jhall Kawasaki ATV and Mule 3 03-19-2006 12:06 PM
