Old 07-28-2007   #1 (permalink)
sw74gls
Riding Is Freedom
Unhappy Klf 400 Starting problem
Hi just joined today, i have a problem with my Klf 400 starting, it backfires, and kicks back (and hurts your shins), and can take a lot of kicks 50 or so until it fires up, once started and warm she runs fine until the next time, also if you put choke on or throttle while trying to start it kicks back violently, I have changed plug, air filter, cleaned the carb (was'nt dirty), battery is good, spark is good, im stuck, as i say once it finally starts without kicking back she runs lovely up and down the rpm range no problem, I would really appreciate you're suggestions, many thanks...
sw74gls is offline   Reply With Quote
Old 07-29-2007   #2 (permalink)
Ausmarty
Spend most time under it
I have a similar problem that I have been trying to nail down for some months now, It's destroyed 2 starter reduction gears and the main flywheel sprocket from the backfiring,seems like the timing is to far retarted and kicks back, Iv'e done the carb battery gone through all the electrical system to no avail, sometimes it just loses spark you come back 5 mins later and it fires straight up.
I'm thinking it could possibly be an ignition coil, the pickup coil that sends the signal to the cdi or the cdi itself, Which if you go by process of elimination will get quite costly.
Sorry if I have hijacked your thread but I or we would be interested to hear of anyone that has gone down the same path
Cheers, Marty
Ausmarty is offline   Reply With Quote
Old 07-30-2007   #3 (permalink)
YurFatMom
Jedi master
YurFatMom's Avatar
I would check the timing and check the compression. It could also be that you have the carbs mixture screw set too lean.
'03 YZ250
'03 Kodiak 400
'05 YFZ450
I turned blue!
YurFatMom is offline   Reply With Quote
Old 07-30-2007   #4 (permalink)
Ausmarty
Thanks for your reply ourfatmom, The pulser coil which runs off the flywheel is not adjustable so the advance retard is done through the cdi, In my case the rings and valves have just all been redone, I have tried the mixture but didn't notice much difference, It also idles a bit rough only sometimes to a stage it will die, if I set the idle a bit higher it seems to be ok.
How about you sw74gls ?
Starting problem!!! 2005 ZX6R suthrn_zxr Kawasaki Streetbikes/Sportbikes 8 04-23-2007 04:31 PM
Starting Problem!!! 2005 Ninja ZX6R suthrn_zxr The Mechanics Corner 2 04-19-2007 01:04 PM
220 Bayou cold starting problem lexluther Kawasaki ATV and Mule 0 02-21-2006 09:20 PM
Starting problem bdutton Kawasaki Streetbikes/Sportbikes 1 04-19-2005 07:33 PM
Strange Starting Problem With 2002 1500FI lylemills Kawasaki Cruisers 1 04-11-2005 09:46 PM
