Old 12-12-2007   #1 (permalink)
mdmkjm
Default Mule 3010 won't start
I just recently had the valves checked at 560hrs, and it started 'ok' when the weather was warmer. I have this in a basement garage, and can't get this started at all now even with starter fluid. I know these are cold natured. Any suggestions for making these start easier? Are there any kind of engine warmers available for these? Thanks,
mdmkjm is offline   Reply With Quote
Old 12-12-2007   #2 (permalink)
RCW
Wants better weather!
If it is a gas rig, make sure the ignition is working. I recommend picking up both a spare set of spark plugs, and then one of those cheap spark checking devices and make sure you are firing a spark to the plugs. If the spark plugs are working, and the choke was open while you sprayed in the starting fluid, it will start - guaranteed.
The most common problem with not starting in cold weather is over choking and flooding the plugs so they will not spark.
Other things to look for is corrosion on the ECM or key switch connections, resulting in no ignition at all. Sometimes, part number 21199, the igniter; or 59026, the pulsing coil can fail or have wet and corroded contacts.
If the rig has been starting hard and taking a long time to warm up, and then conking out once in a while in warmer weather, then I would lean toward the igniter or pulsing coil as the source of your problem. The last two items do not fail that often, but when they do you start having low power, difficulty in keeping them running when cold, and an occasional time when the engine just dies for no reason.
Most often they are damaged when someone jump starts the Mule from a running car or truck. The car or truck alternator overruns the Mule's electrical system and blows the internal IC's in one or both of those parts.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 12-13-2007   #3 (permalink)
mdmkjm
Thank you very much! It is gas so I will certainly check the plugs and investigate your other suggestions. Thanks again.
Old 12-17-2007   #4 (permalink)
mdmkjm
My problem ended up being a clogged in-line fuel screen. It's the little 1" screen that is in the fuel line right before the carburetor. It was full of fuel varnish. Had I known it was there, I would have checked that first. I've learned a ton just with this little problem!! Chalk it up to experience.
3010 Mule Drive Belt Problems JCloyed Kawasaki ATV and Mule 2 07-30-2007 02:21 AM
2007 3010 Trans mule minirancher Kawasaki ATV and Mule 2 06-18-2007 05:06 AM
Mule 3010 Diesel Cup Holder Zero-Point Kawasaki ATV and Mule 6 06-18-2007 04:20 AM
Mule 3010 idle and jetting supermotard Kawasaki ATV and Mule 5 02-14-2007 02:27 AM
Mule 2510 won't start gcaviness Kawasaki ATV and Mule 2 05-03-2005 07:57 AM
