05 Brute Force 4x4 problem... Help!?
+ Reply to Thread
Results 1 to 3 of 3
Thread: 05 Brute Force 4x4 problem... Help!?
  1. #1
    Cruising In Fourth Gear BTK Intermediate
    Join Date
    Apr 2005
    Location
    S.W. Michigan
    Posts
    219
    Default 05 Brute Force 4x4 problem... Help!?
    Went out to plow last night and the unit was in 2wd. Flipped the switch to 4 wheel drive and nothing. Moved forward nothing. Plowed the drive no problem in 2 wheel drive but never could get 4wd to engage. I have never engaged the 4wheel drive switch while the unit is moving as I have heard that can destroy the front diff. A couple weeks earlier I had it on the hunting property and there were no problems or no sign of a problem. I thought maybe a fuse but there isn't one specificaly for the 4x4 function and all other functions seem to working just fine. I'm guessing a bad actuator but??? How difficult is that to replace? Expensive? Any other ideas?
    2009 Kawasaki Teryx LE
    Warn Winch
    Moose Racing plow
    2009 Yamaha Royal Star Tour Deluxe
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    RCW
    RCW is offline
    Needs A Real Job BTK Expert
    Join Date
    Nov 2007
    Location
    Oregon, Chile, Alberta, Texas
    Posts
    3,645
    Usually what happens is the actuator gets some moisture and freezes. Try your wife's hair dryer on the actuator and it will likely shift right in. Just do not overheat the unit, only make it warm enough that it is warm to touch.
    If toys will get me in the door when it is time to go, I have it made!
  4. #3
    Join Date
    Apr 2005
    Location
    S.W. Michigan
    Posts
    219
    Thanks! That could be it actually. We had 3-4 days with single digit temps and it's still in the low 20's during the day and single digit temps at night. I will give that a try, thanks.
    Warn Winch
    Moose Racing plow
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. HELP! Persistant Problems with Brute Force 750
    By DustinSwin in forum Kawasaki ATV and Mule
    Last Post: 08-03-2010, 10:11 PM
  2. Mule 1000 ignition problem
    By GenePete in forum Kawasaki ATV and Mule
    Last Post: 08-13-2008, 07:02 PM
  3. Carb Problem 2000 Bayou 300 4x4
    By latenitehobo in forum Kawasaki ATV and Mule
    Last Post: 02-25-2007, 07:30 AM
  4. 2005 Brute Force 650 Starting Problems
    By waterdog174 in forum Kawasaki ATV and Mule
    Last Post: 12-18-2006, 07:43 PM
  5. Brute Force Radiator, from a different Model
    By livin_loud06 in forum Kawasaki ATV and Mule
    Last Post: 12-30-2005, 02:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
