Old 02-08-2008   #1 (permalink)
BIGDAWG
Default fuel jets for mule 3010 4x4
i bought my mules used and from a 3000 ft elevation and i live in a 6500 ft elevation - some say i dont need to change jets and some say yes - i am only getting about 10 miles per gallon - can anyone tell me wat the av per gallon is on a 600cc mule 3010 4x4 (gas) thank you
BIGDAWG is offline   Reply With Quote
Old 02-08-2008   #2 (permalink)
RCW
Way Too Much Free Time
A well tuned gas 3010 will get in the teens.
The best way to know if you are jetted too rich is to read the spark plugs for color and carbon deposits.
I normally drop a size on the pilot and one or two sizes on the main jet over 4,500 to 6,500, then drop another size on the main over 6,500 feet. Since your machine was from 3,000 it may already be dropped one size on the mains, but likely still has the OEM pilot.
Fuel economy is most greatly impacted by the pilot jet, as the constant velocity nature of the carb tends to limit impact of rich mains to some extent, you just will not have full power it is sized properly.
A really good way to know if the pilot jets are too large is to set the bleed air screw in to just finger snug on the seat and then back it out 1 and one half turns. If the machine idles like a slug until you back the air bleed screw out another turn or more, then the pilot is too rich (large).
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 02-09-2008   #3 (permalink)
BIGDAWG
thank you so much - the info is well received
roger
Fuel pump problem on 3010 4x4 Mule Daryl Melancon The Mechanics Corner 0 07-09-2007 09:14 AM
3010 Diesel Water in Fuel jcbdc Kawasaki ATV and Mule 4 06-17-2007 11:37 AM
won't run w/o the choke!! NEwbie!! cowzx750r The Mechanics Corner 22 05-03-2007 08:56 PM
OK I Give up! What Is SeaFoam? msa1956 Kawasaki Cruisers 22 07-22-2006 01:46 PM
Very little fuel coming out the main jets..., why? makenzie71 Kawasaki Streetbikes/Sportbikes 17 02-14-2005 08:39 AM
