Old 05-04-2008   #1 (permalink)
08BF750
Default 08 brute force 750 problems slipping
Hi
I just recently bought a new 08 Brute Force 750. I have 26in terra cross tires, and 12 inch ITP SS 108's It has 127 hrs on it.
My Problem, in high gear, if you give it a little gas it seems like it slips a little bit, then picks up and go's on. It dosent seem to do this in reverse or low. I havent asked the dealer about it yet, just wondering what you guys might think. I havent been rough on it. No mud holes. One creek that wasnt bad. just wondering what you think about it.
08BF750 is offline   Reply With Quote
Old 05-05-2008   #2 (permalink)
RCW
Way Too Much Free Time
From the symptoms and the tire size you list, I would suspect you have a glazed belt. Once you increase the tire diameter it increases the torque requirement for the belt and after about a 100 hours the belt is pretty much toast. It is just a trade off that most people live with.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 05-05-2008   #3 (permalink)
08BF750
Im sorry, I forgot to add that it had these symptoms before I put on the tires. What else might caused a glazed belt.
Thanks
08 Brute Force 750 (Black with Red racks)
12 ITP SS108
26in Terra Cross Tires
2500lb Ramsey Winch
Old 05-05-2008   #4 (permalink)
RCW
Nailing the throttle and spinning the wheels or going for maximum acceleration are the most common ways to glaze a belt. Running one wet and letting it squeak itself dry is another.
1979 XS650 Yamaha
New DR-Z400S
Old 05-05-2008   #5 (permalink)
Mercury
Mercury's Avatar
Send a message via AIM to Mercury
Originally Posted by 08BF750 View Post
Hi
my atv p360 4x4 2003 did the same exact thing, while it was under war. i brought it back and they said it was still in tolerance (the belt tension) but they put it on the other side of the tolerance... was much better then
ALSO with larger tires, consider different clutch springs...
epi springs
https://www.erlandsonperformance.com...=atvpolsprings
good luck
kenny
2000 drifter 800 - lightly modded
2003 360 4x4 atv
Mercury is offline   Reply With Quote
Old 05-06-2008   #6 (permalink)
08BF750
Thanks for the help guys. This is my first Four Wheeler, how much can I expect to pay for a belt.
12 ITP SS108
2500lb Ramsey Winch
Old 05-06-2008   #7 (permalink)
Mercury
Mercury's Avatar
my belt was 70 bux, I doubt you need a belt
kenny
2003 360 4x4 atv
Old 05-07-2008   #8 (permalink)
08BF750
Do you guys think a heavy duty belt might help my problem
12 ITP SS108
2500lb Ramsey Winch
Old 05-07-2008   #9 (permalink)
Mercury
Mercury's Avatar
NO
As i said, clutch springs, and shimming the secondary so that it grabs harder
you have different sized tires, it will slip a little, but remember it slips only to get going.
Has the belt ever been wet?
ken
2003 360 4x4 atv
Old 02-01-2009   #10 (permalink)
gahesson
Hey guys and/or gals I am new to forums and recently purchased a used 06 b.f. 750i we rode at car dealership it seemed ok has 970 Pretty sure I'll need a new belt but I would think it'll be ok till 1000 but I got home opened it up on 27 acres once it gets good and warmed up it slips completely out of gear not in the notch but you here it grinding like you didn't pull in the brake to change and you have to come to a complete stop then just tap and its back in gear anyone got any ideas?
gahesson is offline   Reply With Quote
Old 02-01-2009   #11 (permalink)
Mercury
Mercury's Avatar
i am not sure i fullly understand but you should only switch gears from reverse to neutral to high or low when STOPPED... no grinding should ocur!
kenny
2003 360 4x4 atv
Old 02-02-2009   #12 (permalink)
gahesson
Its not when your stopped, its after you've been riding about 10-15 min when the machine is warmed up, you gas it going about 35-45 mph the shifter does not move but the macine is not in gear either you are suspened btween neutral and high the machine is coasting and grinding at the same time, once you get stopped you can just tap on the shifter and it pops back into high and you can take off again till it happens again.
Old 02-02-2009   #13 (permalink)
okieduc104
Cruising In Fourth Gear
okieduc104's Avatar
Your transmision is jumping out of gear and the linkage is trying to reengage the gear, making a grinding sound, you need to have the engine at an idle to keep the driven shaft from turning and grinding, when the engine is above an idle the torque convertor is turning the driven shaft. It is like in a stick shift car when you would try to shift with the engine reved up and not engaging the clutch, eventually you could badly damage the transmission even further than it already is. You probably have a linkage out of adjustment or a shifter dog and gear shifting groove worn and that allows the transmission to jump put of gear under power. It is going to be expensive now but a lot more expensive if you don't get it fixed. (In My Humble Opinion)
okieduc104 is offline   Reply With Quote
Old 02-02-2009   #14 (permalink)
Mercury
Mercury's Avatar
does it jump out of low gear?
i would bet not
kenny
2003 360 4x4 atv
Old 02-02-2009   #15 (permalink)
okieduc104
okieduc104's Avatar
i would bet not
kenny
So if it does not jump out of low gear what do you think the cause is?
Then if it does jump out of low gear and high gear both, what do you think the cause is?
Thanks, One a linkage problem, and the other an internal gear problem or a detent?
Old 02-02-2009   #16 (permalink)
gahesson
I did not try it to see if it would jump out of Low gear. I was afraid of burning up the trans.
When I purchased the machine there was a miss in the idol. A friend of mine was with me and we figured it was Spark plugs. The front one was not a problem to fix. The back one however was aweful, and the linkage was in the way. I may have put a little to much pressure on it to try and get my fingures back to the plug.
Is this linkage that Fragile or sensitive.
Clear Tail Light Lens Cover Brute Force 650 onehotride Kawasaki ATV and Mule 1 08-01-2007 01:48 PM
Kz 750 that is starting to have problems riverbed The Mechanics Corner 1 09-20-2004 07:17 PM
Starter problems -1983 KZ 750 LTD ww_big_al Vintage Motorcyle Info 0 08-20-2004 09:10 PM
Problems charging the battery on a 2002 Vulcan 750 Esprit The Mechanics Corner 2 01-27-2004 02:08 PM
Charging problems with my 750 2002 vulcans Esprit Main Lobby 1 01-27-2004 11:08 AM
