LinkBack | Thread Tools |
I have a 1995 Bayou 300 4x4. The charging system seems to be delivering too much voltage and causing the battery to boil over. I put a volt-meter on my battery terminals when the quad was running and got about 16.5v at idle and around 17.4v when revved up. According to the Haynes manual the maximum voltage here should be 15.0v.
I'm thinking that I need a new voltage regulator/rectifier. Has anyone here encountered a similar problem? Does this diagnosis sound correct, or could something else be causing this problem? Any input will be greatly appreciated. Thanks! |
#4 (permalink) |
Can't find time to ride
If the battery is partially sulphated it will cause the charging system to charge up over 18 volts, and boil the water out of the battery. So make sure you have a good battery before replacing the regulator or the problem will still be there $120 later.
2008 3010 Trans4X4 Diesel Mule 2008 JD XUV 850 Diesel 1979 XS650 Yamaha New DR-Z400S |
#6 (permalink) |
Sit speling cheker
hey good to hear that took care of it your welcome and 1 more thing did you apply a little die electric grease to your voltage reg connecter to prevent corrosion and water intrusin it would be safe to do that being they are not cheap things to replace i bet -corey-
| 89 Bayou 300 backfires & coughs above idle speed | jguenthe | The Mechanics Corner | 12 | 2 Weeks Ago 05:09 AM |
| Bayou 300 carb problems | antiqucycle | Kawasaki ATV and Mule | 43 | 2 Weeks Ago 11:38 PM |
| Replacement Carb for Bayou 300 | antiqucycle | The Mechanics Corner | 8 | 11-22-2007 12:24 PM |
| bayou 300 rear diff. interchange | preacher | Main Lobby | 1 | 08-25-2006 12:25 PM |
| Replacement starter relay/solenoid | therealSnafoo | The Mechanics Corner | 13 | 04-04-2006 09:02 AM |
