Old 05-12-2008   #1 (permalink)
joyfulone_74
Send a message via Skype™ to joyfulone_74
Angry Terrible problems with my Mule
Hello all,
I have a brand new mule 610 4x4 and I am having a terrible time with it. It has 2 hours on it. And will not go anywhere. : ( I can’t just take it to get serviced since I live in rural Alaska and getting to the service department is 2 plane rides away.
I had a friend work on it and he changed the spark plug and adjusted the idle. He let it run for about 30 minutes and then took it down the road to the dump and back. We thought all was well. The next day I started it and let it warm up a while, loaded it up with boxes for the post office, didn’t even make it to the road. It will start and idle for a while, but if you put into gear and step on the gas it will either sputter and die or backfire and die.
My friends have looked at all the fuel lines to check them and taken out the carburetor and inspected it and could not find anything that would be preventing it from running.
Can anyone offer up any ideas on what else to check?
Thanks and have a great day!
Joy
joyfulone_74 is offline   Reply With Quote
Old 05-12-2008   #2 (permalink)
kc6wfs
Plasma Blue
kc6wfs's Avatar
choke sticking.. or bad gas???
2007 Vulcan 900 Custom Plasma Blue --
www.myspace.com/nitrophotos
kc6wfs is offline   Reply With Quote
Old 05-12-2008   #3 (permalink)
joyfulone_74
No problem with the choke and the gas was brand new so I wouldn't think so.
Old 05-13-2008   #4 (permalink)
RCW
Check the pulse line from the engine to the fuel pump, make sure it is attached and has not shaken loose in shipment. You will see the line running out of the crankcase through a breather water trap, and into the fuel pump to drive the diaphragm. If it gets loose the fuel pump will not work as it should. If the breather water trap fills with water and freezes, it can crack and leak the air pulses needed to run the fuel pump.
It could be a faulty spark plug, or a bad coil. If it starts right up after it quits, and will only run at an idle, then look to the fuel system. If it will not start right up after it quits, and you are sure it has fuel in the carburetor, then check to be sure you have spark at the plug wire. If not, it is the coil. A defective coil will quit when they are warm or start cutting out at higher engine speeds.
The problem sounds fuel related, and could either be the fuel pump, the filter, or the carburetor.
If it starts right up after it dies, and will idle with no trouble, but then dies when you give it the gas, I would check the fuel filter first. If that is not the problem, then you will need to disassemble the carburetor and pay particular attention to making sure the jets and passages are all open.
If it will not start right up after it dies, then pull the bold at the bottom of the carburetor bowl and see if gas runs out. If it does not, then it is either the fuel pump, the fuel filter, or the float needle has a blockage.
There is another thing you can try, and I would probably would before I did anything else once I knew the pulse line to the fuel pump was attached. Drain the gas and the carburetor, then put a gallon of aviation gasoline in the tank. If it starts right up and runs fine, then it is your gasoline. The automotive gasoline we have now days goes bad in just a few weeks, it has way too much alcohol in the blend and starts breaking down as soon as it is exposed to air.
2008 KLR650
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
Mule 2510 Starting Problems. tradewinds Kawasaki ATV and Mule 9 03-06-2008 06:50 PM
mule 3010 oil in air filter problems cody25 Kawasaki ATV and Mule 14 12-13-2007 09:28 AM
mule 610 steering problems dsims The Mechanics Corner 1 01-25-2007 12:57 PM
Strange Mule problems Need help.... RandellH Kawasaki ATV and Mule 5 12-19-2006 07:25 PM
Mule Idle Problems RACER28 Kawasaki ATV and Mule 2 10-08-2005 12:22 AM
