Old 06-21-2008   #1 (permalink)
jessexr
Default 2010 specs
Hey guys..i was wondering if anyone knew or had a manual for a 1990 2010 mule...i need the torque specs for the rod bolts...cylinder head and the valve clearance.I checked the kawaski web site and they have no info for that model....thanks in advance guys Kevin
jessexr is offline   Reply With Quote
Old 06-22-2008   #2 (permalink)
RCW
Way Too Much Free Time
Your best bet is to pick up the repair manual and the latest supplement. If I remember correctly Kawasaki dropped the torque rating method on that engine and updated to a quarter turn break-over process after setting the initial torque value to keep from blowing head gaskets. You also do not reuse the old head bolts, they are a one time deal.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 09-29-2009   #3 (permalink)
lost in utah
lost in utah
i just picked one up at repairmanual.com last mont for my 90 2010 the manual is easy to get but good luck finding parts that is my problem if you know where to find motor parts let me know please.
lost in utah is offline   Reply With Quote
Old 09-29-2009   #4 (permalink)
RCW
The motor is the same as the Kawasaki LTD 450 motorcycle. Parts are still available for that engine.
1979 XS650 Yamaha
New DR-Z400S
1985 ZN1100 Tuneup specs. 79XS The Mechanics Corner 7 09-04-2008 04:51 PM
Torque Specs? VindianaJones Kawasaki Cruisers 6 05-15-2008 02:33 PM
89 ex 500 fule leak left carb i need carb specs elvis The Mechanics Corner 3 10-03-2007 09:01 PM
torque specs ex500 ninja6r Kawasaki Streetbikes/Sportbikes 0 10-04-2005 11:26 PM
I NEED FULL TORQUE SPECS ON MY 92 ZX-7R ENGINE INTERNALS sacramentoboy916 The Mechanics Corner 2 01-10-2004 12:41 AM
