Old 07-05-2008   #1 (permalink)
peachtree
Question Mule 1000 Driven Clutch
I'm new to the forum and have a 1988 Mule 1000. The driven clutch makes alot of noise but works. The dealer replaced the rollers and guides, but still the noise. Anybody know where I can get a complete used driven clutch. Thanks!
peachtree is offline   Reply With Quote
Old 07-05-2008   #2 (permalink)
RCW
Can't find time to ride
Used clutches are a waste of time unless they have been rebuilt by a skilled and experienced mechanic. You can find them on E-bay all the time, and they generally make reasonably good doorstops if you do not mind tripping over them.
If you live near any snowmobile repair businesses, take your driven clutch in to them and have it rebuilt. You will be money ahead in the long run.
The driven clutch has three very inexpensive bushings, two under $5 and one under $10, and three $1.49 poly shoes that ride on the helix that are critical. My guess is once those are changed your noise will quit. There are no rollers or weights in the driven clutch.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 07-05-2008   #3 (permalink)
peachtree
Thumbs up
Thanks for the info! I thought a used one might be junk. I live in south florida so no snowmobile dealers here.
Clutch Handle Won't Disengage (lots of pics here) hanilrez Vintage Motorcyle Info 13 05-10-2008 01:41 PM
Mule 1000 compression. and governer jaslelagra Kawasaki ATV and Mule 2 05-01-2008 03:08 PM
Mule 1000 engine? rosebud Kawasaki ATV and Mule 9 05-15-2007 12:39 PM
kz 400 starter on a kz 440? Alibi Vintage Motorcyle Info 6 03-16-2007 12:08 AM
mule 1000 motor terryw Kawasaki ATV and Mule 3 11-28-2006 10:13 AM
