Old 2 Weeks Ago   #1 (permalink)
tsankou1
Default kawasaki bayou 220 question
would it make any difference in speed and most importantly power if i add a stage 1 jet kit and a knn air filter and oil filter? what do u recommmend?? thanks
tsankou1 is offline   Reply With Quote
Old 2 Weeks Ago   #2 (permalink)
86klf300guy
Clutch Cadet
86klf300guy's Avatar
power yes speed no due to the rear end gears are not changeable you can get maybe 5 -6 horse power gain but its really not worth it unless you plan on raceing or want better throttle responce keep this in mind the more power you make the faster the motor will burn up rings and piston etc its best to leave it stock if you want longjivity out of your machine my bike is a 86 and i bought it used from a 1 owner and when i got it i had to rebuild the top end it was original parts that i took out so that means it lasted 20-21 yrs on a top end -corey-
Kawasaki can make you sick. Uncle Bob Off Topic 20 1 Week Ago 09:47 PM
Kawasaki Bayou 220 problem Pollux Kawasaki ATV and Mule 17 10-26-2007 09:30 PM
Kawasaki 250cc Rants&Raves Specialist ZX-2R Main Lobby 41 10-12-2007 05:06 PM
2000 Kawasaki Bayou 220 bmroyer The Mechanics Corner 0 09-06-2007 07:26 PM
newbie bayou 220 question gunner Kawasaki ATV and Mule 3 10-01-2005 08:19 PM
