Can't find time to ride
The igniter almost never fails. If it does the problem is generally a bad ground or poor connections between the battery and the components of the ignition system, or bad contacts in the ignition switch. Especially if the unit is run in water or in very humid climates.
When one goes it is a good idea to remove the pulsing coil, and the ignition coils and have them tested at the same time you have the igniter tested. Never replace one without having it tested first. If an ignition coil is drawing too much power from a winding failure they will overload the igniter box and can cause it to fail. Turning the key on and not running the Mule at the same time will also cause igniter box failures.
2008 3010 Trans4X4 Diesel Mule 2008 JD XUV 850 Diesel 1979 XS650 Yamaha New DR-Z400S |
| Wheels/tires for mule 1000 | jaslelagra | Kawasaki ATV and Mule | 3 | 04-29-2008 06:10 PM |
| Mule 1000 Help,,,, parts !! | HB` | Kawasaki ATV and Mule | 18 | 04-09-2008 05:33 PM |
| Mule 1000 Transmission | knee2sack | Kawasaki ATV and Mule | 4 | 07-09-2007 12:16 PM |
| mule 1000??? | BRADLEYRL | Kawasaki ATV and Mule | 4 | 12-15-2006 10:02 PM |
| Garage Sale Mule 1000 Noisy Engine | Bent Pegs | Kawasaki ATV and Mule | 4 | 06-04-2006 09:21 PM |
