Old 08-13-2008   #1 (permalink)
Huntin Nut
Default Need Help-- Prairie 300
I have a Kawasaki Prairie 300 4x2 automatic. I believe it's a 2000 model or earlier.
Last week while loading it into the bed of my pickup, it fell off the ramp onto the ground, rolling on it's side.
Since then, it's been leaking oil in 2-3 spots-- mostly toward the back.
It still cranks and runs fine but I've only ran it from the truck into the garage.
I'm not very mechanical. It appears to be oil...... could it be oil+gas....... could it be trans oil........ ? I'd appreciate any help/advise on what the problem could be.
THANKS.
Huntin Nut is offline   Reply With Quote
Old 08-13-2008   #2 (permalink)
RCW
Wants better weather!
If you tip a Prairie over the engine oil will run back up the crankcase vent and run into the air filter housing. I suspect if you clean the air cleaner and clean all the oil out of that housing your dripping will stop.
This sort of thing hardly ever presents any real mechanical problem, just creates a mess.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Need help 2001 Prairie 300 backfiring NEPAKawi Kawasaki ATV and Mule 8 08-14-2008 10:26 PM
Prairie 300 idle problems lonestardjb Kawasaki ATV and Mule 2 07-02-2007 04:46 PM
Prairie 300 trouble starting. steve180 Kawasaki ATV and Mule 1 05-16-2007 11:57 PM
Kawasaki Prairie 300 4X4 Thingie Kawasaki ATV and Mule 2 03-27-2007 10:44 AM
Replacement starter relay/solenoid therealSnafoo The Mechanics Corner 13 04-04-2006 10:02 AM
