Old 08-16-2008   #1 (permalink)
bigbayou
Default stupid question
should the oil level on the side sight glass be on the full mark while running or while turned off ?
bigbayou is offline   Reply With Quote
Old 08-16-2008   #2 (permalink)
RCW
Wants better weather!
Not a stupid question. The best way to check oil is to do it before starting with the oil in the middle of the glass. Then start and run it three minutes, and then check it again in one minute. That way you know you are full.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 08-16-2008   #3 (permalink)
messer00
What a STUPID question !!!!
(Just Kidding)
messer00 is offline   Reply With Quote
Old 08-17-2008   #4 (permalink)
jbsmd
nu2kawi
jbsmd's Avatar
They say there is no such thing as a stupid question. Check your oil when it's off. Got any more stupid questions?
07, Z1000
01, XVS1100LC Yam cust.
jbsmd is offline   Reply With Quote
Old 08-17-2008   #5 (permalink)
86klf300guy
Can't find time to ride
86klf300guy's Avatar
theres no such thing as a stupid question just stupid answers, the manual will tell you how much oil is suppose to be used in a motor or call your local dealer and they will tell how much oil it takes with or with out filter change most bayous take about 2 1/2 gts to fill with filter change and when they are running you will no see oil in the glass it is being pumped around the engine and trans -corey-
Old 08-17-2008   #6 (permalink)
jbsmd
nu2kawi
jbsmd's Avatar
Everything you wanted to know, plus the answer to your question. Good Info.
07, Z1000
Newbie stupid question bubbafunk31 The Mechanics Corner 15 04-30-2008 05:46 PM
Stupid question A2rider Vintage Motorcyle Info 27 02-02-2007 02:26 PM
stupid question: Rick_in_P.A Wa. Vintage Motorcyle Info 11 11-15-2006 04:03 PM
Stupid Question? Reikon Off Topic 102 03-14-2005 12:15 PM
Stupid Question Da Ova Cussa Kawasaki Cruisers 10 02-15-2005 01:09 AM
