Old 08-17-2008   #1 (permalink)
raasp
Default 03 Prairie 650
Hey All,
My MPH and front wheel drive both went out at the same time. checked
fuses.... all good. Everything else runs great.
Thanks, Ray
raasp is offline   Reply With Quote
Old 08-17-2008   #2 (permalink)
RCW
Wants better weather!
That can be the result of any number of causes, but I would check the wiring loom to the instruments, behind the cowl and make sure all your connectors are both clean and lubed with dielectric grease. Go through the entire wiring loom all the way to the battery and the voltage regulator. Also, check your battery to frame ground and the regulator mounting bolt for any rust or corrosion.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 08-17-2008   #3 (permalink)
02prairie 650
just got 02 prairie 650 are their any speed mods i can do i have a honda i cut spring in carp i half it helped alot thanks
02prairie 650 is offline   Reply With Quote
Old 08-17-2008   #4 (permalink)
1400pilot
UBER CLUB MEMBER #2
1400pilot's Avatar
Originally Posted by raasp View Post
Hey All,
Thanks, Ray
more than likely the speed sensor under the clutch cover on the right side of the engine just above rear brake pivot lever....it has 3 wires going to it, and I have seen many of them break
Click for a map of the states I've ridden in
08 ZG1400 Concours
06 KDX200
04KX65
1400pilot is offline   Reply With Quote
650 Prairie belt noise Travmo Kawasaki ATV and Mule 7 1 Week Ago 06:20 PM
2003 Prairie 650 4x4 shifing issues, Belt light, running bad - Help Kawasaki King Kawasaki ATV and Mule 4 10-18-2008 11:59 AM
WTB: Oil Pressure Switch & Fuel Level Switch for 81 KZ-750 Little B Streetbikes Buy/Sell/Trade 0 12-11-2007 01:10 PM
2002 Prairie 650 boggs down usry28 Main Lobby 0 09-08-2006 08:04 PM
Prairie 650 Valve adjustment TrailBuster Kawasaki ATV and Mule 2 07-28-2005 02:41 PM
