Old 08-18-2008   #1 (permalink)
Richardm
Default 1989 Bayou 220 shifting problem -help
I need some help. I have a 1989 Bayou 220 with a shifting problem. It does not want to lock into first gear and the shift lever has to be lifted many times before it will go into first gear but even then, I am still not getting a "Click" like usual. Once there, it shifts into other gears fine and will click into each other gear. Reverse works fine as well. Any ideas??? Thanks
Richardm is offline   Reply With Quote
Old 08-18-2008   #2 (permalink)
RCW
Wants better weather!
Log in to Kawasaki.com and go to the parts diagrams for your machine. There are two diagrams that you want to look at, the first is the gear change mechanism, and the second is the change drum/shift fork.
What you want to pay attention to is how the shift lever actuates a cam that rolls the shift drum. I suspect your problem is the spring that holds the change position lever to the gear change drum cam, or the bolt that holds the cam to the drum is loose. Either of the three rollers that index the change cam can be the problem too, but not likely if you can shift and hold all the other gears.
Take your service/repair manual and go to the section on the transmission and shift mechanism and you will find that it is not a difficult fix. Do not attempt it without the manual.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 08-18-2008   #3 (permalink)
Richardm
Default 1989 Bayou
Thanks very much for your suggestion. I am reasonably handy with working on stuff like this but have never had to spin a wrench on this yet. I need to pick up a workshop manual as you suggested, is there one that you would recommend? and also, should I remove the engine to work on it or can it be done on the frame? Is there any special tools required for this type of repair?
Thanks a million.
Old 08-18-2008   #4 (permalink)
valerie811
I would look at your shifting fork.
valerie811 is offline   Reply With Quote
Old 08-18-2008   #5 (permalink)
Richardm
Thanks, I need a workshop repair manual, would you recommend a factory or aftermarket?
Old 08-19-2008   #6 (permalink)
RCW
I would select the factory manual over the aftermarket version, but both are good. If you call the number in the ad at the top and give them your member id, you will get a discount, and it is a good way to keep this forum going.
1979 XS650 Yamaha
New DR-Z400S
Old 08-19-2008   #7 (permalink)
Richardm
Thanks, will do
Bayou 220 owners out there stan Kawasaki ATV and Mule 51 2 Weeks Ago 08:02 AM
Bayou 220 Fuel issue tsankou1 The Mechanics Corner 1 08-07-2008 07:22 PM
bayou 220 starting problem rlmmc Kawasaki ATV and Mule 5 08-09-2007 01:04 PM
bayou 220 stator, pre-1996 trade/buy read! farmereinar Accessory Swap Meet 2 06-13-2007 10:32 PM
KLF 220 Bayou Shifting problem KLF@@) Kawasaki ATV and Mule 1 09-10-2006 08:22 PM
