Old 08-19-2008   #1 (permalink)
fliper
Default valve on prairie green team 700
hi i have ajusting the valve clearance on my bike (prairie 700 2006) the problem is i can't fix the clearance like the bike book tell me to fix it is suppose to be .010 for intake and .020 for exaust whit this clearance the valve snap, i have fix at .006 for intake and .010 for exaust and the bike run verry good like that, the tf and tr mark was in good position when i have made it if some one can tell me why i have to reduce the clearance to have no valve snap thanks
fliper is offline   Reply With Quote
Old 08-19-2008   #2 (permalink)
RCW
Wants better weather!
Be sure you are using a metric feeler gauge, the intakes should be set between .10 and .15mm, not inches. This will likely solve your noise problem. If you use an inch based feeler they will rattle like rocks in a box.
The exhaust should be set between .20 and .25mm. If you ride hard or pull a load go with the looser of the settings on the exhaust valves. They tend to expand more with heat than the intake valves.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 08-20-2008   #3 (permalink)
fliper
you got right rcw i have found a feeler gauge whit the right clearance my feeler gauge was in inch and centimeter but i'm not have to fix my valve again because i have fix intake at .006 in = 0.15 mm and exaust at .010 in = 0.25mm thanks for your help verry apriciate
Team Green Needs Your Vote! Liquid force Main Lobby 27 04-13-2007 05:51 PM
7/28: James "bubba" Stewart & Team Green @ Portland Motorcycle! PMC Kawasaki Motocross and Offroad 2 07-21-2006 11:09 AM
AMA Supersport TEAM GREEN Kevlar636 Kawasaki Streetbikes/Sportbikes 12 03-11-2006 03:38 AM
Team Green makes me feel all... steamy inside! neebelung Off Topic 6 06-10-2005 12:38 PM
Team Green neebelung Main Lobby 1 05-18-2005 05:52 PM
