Old 08-20-2008   #1 (permalink)
Xpider
Default KLF300B No Spark, I even Kissed It/Talked sexy to it, and Still Nothing?!?
Hi Guys,
I know Old Topic, New Fella....
I searched the forums (not really), and found some posts,
but nothing Bang-On to my issues.
In Sequence...
Bought 1993 KLF300b Bayou that 'only needed' cdi box (igniter)
Bought and installed CDI Box... No Spark
Tested all electrics from spark plug back except regulator as I don't know how to test it.
Pick-up (Pulser) coil showed no resistance.
Replaced Pick-up Coil ... No Spark
Pulled out some hair, threw some tools around the garage... No Spark
So My Question, may be stupid but....
Is the regulator-rectifier required to get spark/Start the engine?
If Yes, Why? ( I always thought the charging/starting circuits were mostly independant of one another.)
Please help, I promise NOT to Kiss/talk dirty to/pull out hair/throw tools at those who reply this request.
Xpider
You're Not really gonna let me ride this thing, Are Ya?
Xpider is offline   Reply With Quote
Old 08-20-2008   #2 (permalink)
RCW
Wants better weather!
Yes, the voltage regulator is required to initiate and maintain a spark.
The way the Kawasaki CDI system is designed it receives an initial voltage pulse from the pulsing coil, and then the Igniter obtains stable voltage from the battery and voltage regulator to send a full specified voltage pulse to the coil.
Without either one of the battery or the regulator the system will malfunction, or if run with a nearly defunct battery you will send over 20 volt surges to the coil and supersaturate it and burn it out, and burn out the igniter.
I would pull the pulsing coil, the regulator, the igniter, and the ignition coil and take them to your dealer and have them checked. Check the igniter you replaced, it is likely still good if it was OEM Kawasaki.
Another thing to kick around. If you are buying discount igniters and pulsing coils, about 60% of them are defective right out of the box. Same for ignition coils. The discount stuff is either OEM supplier product that will not meet the OEM specifications for performance, or table scraps from China. Either way it is a bad choice. By the way, this is also true of automotive ignition components now days. Buy the best quality you can afford and avoid problems.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 08-20-2008   #3 (permalink)
Xpider
Thanks M8,
For both the reply and the explanation.
They are greatly appreciated.
If you are looking for good deals on brand name PC-parts, hit me with an e-mail or a pm.
X
Old 08-20-2008   #4 (permalink)
86klf300guy
Can't find time to ride
86klf300guy's Avatar
another quick check is to take a test light at the coil its self and check the 2 wires for power 12v one of the wires should pulse while turning over if not then its the pulser/or wireing but if you dont have power at the coil on ethier legs then you have a broken power wire or blown fuse or bad battery/or weak,and if you have pulse and power and allready replaced the coil have the coil tested by the dealer or you may have a bad ignition wire ohms test the wire it should be low ohms dont know the number off hand then do a resistance test on that wire also,good luck with the repairs -corey-
Old 09-03-2008   #5 (permalink)
Xpider
Hi again,
I replaced the pulser, regulator/rectifier, and have at least continuity on all leads. Still no spark. Someone mentioned a woodroff key in another post, but i can't find any information regarding it. Anyone out there know what this elusive device is and how I would check/test it?
Thanks
Old 09-03-2008   #6 (permalink)
unit5alive
Made It To Second Gear
unit5alive's Avatar
Arrow
I think he's talking about the steel key that prevents the flywheel from spinning on the end of the crank , it one of the things that keeps everything in proper time , if you have a flywheel puller you can check to see if it's sheered off , Craig.
07 610camo,roof,f&rbumpers,storagebin,tach,speedo,flr mat,benz silent rider,hitch,turn signals,winch
unit5alive is offline   Reply With Quote
Old 09-03-2008   #7 (permalink)
Xpider
Thanks for the quick reply...
Rgr Tht, the steel key is exactly what I meant, but I looked and it wasn't sheared off, it was gone. Had another one from a different bike, replaced, and still no spark. I'm completely lost now. My next step is to replace the
wiring, 1 lead at a time, and hope to find a broken one quick. I have no other clue what to do.
I WILL hear this bike run. Thanks again for all the help guys. I guess this is Network Tech's don't generally repair 4 stroke fuelled engines.. LOL.
-=[Joey]=-
Old 09-03-2008   #8 (permalink)
RCW
Even if the woodruff key is stripped or lost it will still spark, just out of time. Or, it will make a very loud grinding noise as the flywheel spins on the crankshaft.
If the igniter tested good at the dealer, I would check the thirty amp fuse, and its holder. Then check both solenoids to make sure they are working. You have a starter solenoid and a second solenoid that controls the ignition, etc., that is switched by the key.
Attach your multimeter, set to read DC volts, positive lead to either one of the ignition coil feed lugs and the other to a frame ground, while the coil is hooked up. See if you have a voltage pulse when you crank.
Also try a jumper to the two wires that lead to the ignition switch, or attach your voltmeter to the two harness wires and read the voltage, it should be battery voltage less line loss.
Be real careful about using the ohmmeter on the leads from the igniter, unless you have the repair manual and know exactly which leads to test in what order. It is easy to blow the IC and kiss off the igniter.
1979 XS650 Yamaha
New DR-Z400S
Old 09-03-2008   #9 (permalink)
86klf300guy
are you sure u have power at the coil as rcw stated? thosse 2 wires shold be hot when the key is on and only one wire will pulse while turning the motor over and the other will stay hot no pulse check to see if you have power with a test light and connected to a good ground if you have no power then trace the wire wire down that comes from relay and the fuse holder also as rcw said also but you have to see if you have power at the coil ....-corey-
Old 09-07-2008   #10 (permalink)
Xpider
Thanks again for all the assistance.
I do have power @ the coil, but the voltages seem weak. On the pulsing side,
I'm getting .046 that pulses to .19 . Like I said that seems really weak to me, unless the coil itself is a capacitor that increases the voltage during pass-through.
Just for fun, I took the coil out of my brother's '98 Prairie 400, it's shaped differently and a different model, but was worth a try. Still no spark.
The solenoids both tested good, as did the ignitor, and I'm getting 11.8v at the ignition switch.
In the process of this round of testing, I did find a cut off hot-lead and ground in the harness close to the regulator/rectifier. and I'm wondering if
something is missing or connected wrong. These leads aren't capped or taped, they are bare, and this worries me a bit. I have a wiring diagram from a Bayou 220, and all appears the same, but I'll have to get the proper wiring diagram for my 1991 bayou Klf300B.
I'll post back when I have more information.
Old 09-07-2008   #11 (permalink)
RCW
Your voltage to the ignition switch is way low, just about dead duck. 11.7 vdc and they will never run. Check back to the battery and make sure it is grounded and the main fuse is clean on the terminals.
I would suspect the cut wires are the problem. The way the CDI on these works is the pulsing coil generates a trigger and timing reference, then the igniter uses power from the electrical system to amplify the pulse to the coil.
You may be able to get back behind the loom wrap and determine the color of the cut wires and then splice to the other end, unless someone has cut off the end with the connector that should plug into either the igniter or the regulator. If you have an open socket on the regulator, then that is likely what happened.
1979 XS650 Yamaha
New DR-Z400S
Old 09-07-2008   #12 (permalink)
Xpider
All the connections @ both the reg/rec and cdi ignitor are complete.
The cut wires are White (voltage on this one) and blk/y (ground i would think).
I'll trace them back and let you know where they terminate.
Old 09-08-2008   #13 (permalink)
86klf300guy
yea the coil takes 12v and jumps it up to i think 15 -25,000 v so if you have low volt and the battery is good say the wire goin to the coil is broken inside the casein and will need replaced sounds like you have a fun one there i like workin on them hard to figure out ones lol -corey-
Old 09-09-2008   #14 (permalink)
Xpider
So the Hot side of the coil should read 12v less line loss?
Then my issue is elsewhere, 'cause I only get .046.
How do I hot-wire from the battery directly to the coil?
Old 09-09-2008   #15 (permalink)
RCW
Check the pigtail with the female end on the hot battery cable, and make sure it is connected to the fuse holder and that the fuse and contacts are good.
There is also a male pigtail on the negative battery cable that provides a negative reference. Make sure that pigtail is still connected and not unplugged.
With the CDI used by Kawasaki it is not a good idea to jumper power anywhere but through the wiring harness. Stray voltage can fry the IC in the igniter in a flash.
1979 XS650 Yamaha
New DR-Z400S
