Old 08-21-2008   #1 (permalink)
scott63
Default Bayou 220 Turned Over
Son turned 220 over and now it won't start. I checked carb and cleaned. I have spark and gas but will not start. Is there a kill switch somewhere?
scott63 is offline   Reply With Quote
Old 08-21-2008   #2 (permalink)
86klf300guy
Can't find time to ride
86klf300guy's Avatar
is your son ok? sorry to hear that he rolled hopefully all is well.but for your machine not starting it would be safe to say the kill switch is ok you have spark,but what was the bike turned over in water,mud,grass.if water or mud may have to dry the cylinder out with compressed air if there is any water or fuel in the cylinder makin it wet it will not go bang is your plug wet with fuel? try dryin the cylinder out no matter what ne how it wouldt hurt nothin. and does it turn over ok nothin draging or turning over really fast like no compression?-corey-
Old 08-21-2008   #3 (permalink)
scott63
sounds like turning over really fast.
Old 08-22-2008   #4 (permalink)
86klf300guy
do a compression test first and let us know what that comes out with...-corey-
Old 08-25-2008   #5 (permalink)
scott63
trying to find tester. what should pressure be? I just had rings replaced, new risk pin, new cam.
Old 08-25-2008   #6 (permalink)
86klf300guy
over 120 psi is ok maybe it sheared the cam gear locateing pin also but do that comp test first -corey-also you can use your finger to see if it pops your finger out will serfice also just to see if the valve train is ok but make sure your plug wire is out of the way or itll be a shocking time in the garage lol -
Bayou 220 carburetor clip position. Help! mdgil Kawasaki ATV and Mule 1 04-18-2008 09:20 PM
Bayou 250 motor or 220? Matt R Kawasaki ATV and Mule 5 01-07-2008 09:18 PM
bayou 220 stator, pre-1996 trade/buy read! farmereinar Accessory Swap Meet 2 06-13-2007 10:32 PM
Bayou 220 - Help with Hoses TAQuickness Kawasaki ATV and Mule 6 01-16-2007 11:12 AM
Starter Problem Bayou 220 gkru10@comcast. Kawasaki ATV and Mule 1 03-18-2006 09:31 PM
