I Have A 3010 Mule And Also Know Several Other People That Have Mules And They All Run Like ****, Barely Idle And Start Hard. My Mule Only Has 15 Hrs On It And I Am Having Problems With It Running. The Dealer Says This Is Normal, Does Any One Else Have This Problem Or Any Suggestions.
THANKS RACER28 |
The mules can be finicky - I just had to replace my carb to get mine to idle. Try putting new plugs in first (yes even in a new machine) then try adjusting the enrichment screw and idle speed screw to get a good smooth idle. Don't get your idle to high as that wears out your shiffter cog and drive pinions, it should go into gear with a smooth bumb and no grinding or grabbing
I started having problems with my mule idling when I got around 20hrs on it I brought it back to the dealer and he changed the jet in the carb. I have not had a problem after doing this. My broyher was having the same problem also. They changed the jets for him and he has no problem anymore.
