Old 08-23-2008   #1 (permalink)
CHCINC
Default 07 Bruteforce 650 Trouble Starting When Cold
It's A B!$#% To Start When Cold
CHCINC is offline   Reply With Quote
Old 08-25-2008   #2 (permalink)
RCW
Wants better weather!
The 650 offered a primer option for cold starting, and if that was not added at the time of purchase they can be pretty tough to cold start, to almost impossible when below freezing.
I believe the primer is available as a component assembly from Kawasaki. I recommend you contact the folks at the 800 number in the header ad, and see if they have it available. It may have to be ordered in three or more parts, but should not be very expensive.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
WTB: Oil Pressure Switch & Fuel Level Switch for 81 KZ-750 Little B Streetbikes Buy/Sell/Trade 0 12-11-2007 01:10 PM
220 bayou cold starting problem's.. countryboy546 Kawasaki ATV and Mule 4 12-20-2006 04:07 PM
2005 Brute Force 650 Starting Problems waterdog174 Kawasaki ATV and Mule 3 12-18-2006 08:43 PM
76 kz 650 -starting issues repadijdas The Mechanics Corner 1 10-26-2005 02:03 PM
Cold starting problem jesse1 The Mechanics Corner 4 05-03-2005 12:23 PM
