Old 08-26-2008   #1 (permalink)
Shawn615
Question 03 Bayou 250
Problem is that at mid throttle it starts to break up, and gets a little better at full throttle but still breaking up. Wondering what it could be, is it carborator, ingintor box?? or....????
Shawn615 is offline   Reply With Quote
Old 08-26-2008   #2 (permalink)
RCW
Wants better weather!
The Bayou 250 can break up at mid-throttle from dirty air bleed holes in the needle jet holder. But, I would suspect the ignition coil is starting to go.
A weak coil will start to break down under load, then seem to recover at full throttle when the mixture is the richest. I would pull the ignition coil and have it tested.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 08-27-2008   #3 (permalink)
Shawn615
Thanks, any idea where I can get a diagram? Where is the ignition coil located?
Bayou 250 motor or 220? Matt R Kawasaki ATV and Mule 5 01-07-2008 09:18 PM
bayou 250 water invasian bayou Kawasaki ATV and Mule 4 08-08-2007 11:18 PM
Bayou 250 (2x4) A1, A2 and A3 Differences WVHunter129 Kawasaki ATV and Mule 1 02-14-2007 02:31 AM
bayou 250...Jet kit ...is it worth the money??? L250H Kawasaki ATV and Mule 0 02-12-2007 11:41 PM
bayou 250 stalling and plug filing 2bayouowner Kawasaki ATV and Mule 3 07-12-2006 06:46 PM
