Old 08-26-2008   #1 (permalink)
JCARS
Default 98kvf400 overheating
i have a 1998 kvf 400a.I recently replaced piston rings, valve seals,head gasket and base gasket.Bike runs fine but ever since work was done i'm having problems with overheating.I can drive for 25-30 minutes before temp light comes on.any help would be appreciated.
JCARS is offline   Reply With Quote
Old 08-26-2008   #2 (permalink)
86klf300guy
Can't find time to ride
86klf300guy's Avatar
is the cooling fan comeing on? and also may have a stuck thermostat or water pump impeeler may be broken open radiator cap andsee if the coolant is flowing while cold and let it come up to temp when thermo is to open if not flowing then try a t stat first but you may also have a air pocket in the system that will cause this also.but if the cooling fan is not comein on then you may have a bad temp senser or relay or fan motor or water pump -corey-
Old 08-28-2008   #3 (permalink)
JCARS
Thanks For The Help.it Was The Thermostat.by The Way.i'm A Mazda Mechanic.anything Anyone Needs To Know,don't Hesitate To Ask.thanks Again.
Old 08-29-2008   #4 (permalink)
86klf300guy
well thats good to hear i myself am a tech chrysler and gm certified and a ase master it all sucks workin on em any more id rather fix bikes for a livin i like that better than cars any more lol
thats good it was an easy fix on your machine glad to hear it -corey-
Overheating :( squeak Vintage Motorcyle Info 1 08-17-2006 09:48 PM
overheating problem: NEED HELP!!! 85_en454ltd Kawasaki Cruisers 3 08-09-2006 07:22 PM
Eliminator 250 overheating problem DAX Kawasaki Cruisers 14 08-08-2006 09:33 AM
Eliminator 250 overheating problem DAX The Mechanics Corner 0 08-01-2005 05:35 PM
kawasaki mule overheating markct Kawasaki ATV and Mule 5 09-21-2004 03:17 PM
