Old 09-08-2008   #1 (permalink)
HCfarmer
Default Starter remove and replace on a 2510
I've got a 99 year model 2510. The starter needs to come out and be re built. I've got the kit to do it with, but removing and replacing the starter looks like its going to get pretty involved. Has anyone come up with any shortcuts for this procedure?
Also, has anyone had problems with short life on wheel bearings? Although I cross water quite a bit, I would think they'd last more than one year.
HCfarmer is offline   Reply With Quote
Old 09-08-2008   #2 (permalink)
RCW
Wants better weather!
It is pretty simple to remove the starter, just follow the procedure outlined in the service and repair manual. If it is a gas rig, pay particular attention to disconnecting the negative cable on the battery before you start so you do not blow the Igniter.
My wheel bearings have always lasted the life of the Mule and still been going when I sold them. But, I service them every year and use Hydrotex Hydro-syn 70, not a cheap grease but bearings are not either.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 09-08-2008   #3 (permalink)
HCfarmer
Thanks for the reply. Your right about + cable first. I have seen a lot of ignition systems, as well as automotive ECMs blow from the - being removed first. The worst was on a Diesel Semi. $2,500.00 for the computer
The bearings on mine are non serviceable sealed bearings. I had thought about matching up the bearings with non sealed ones, and putting a grease Zerk in the hub to direct grease into both bearings. However, that would mean a small amount of grease would get into the drum area, and would need periodic cleaning.
Old 09-08-2008   #4 (permalink)
muleboy
There is no real shortcut to getting the starter off. There is not enough room to reach the bolts on the starter without first removing the clutch cover and driven clutch half. It's not a horrible long job but you'll need to either borrow the tool or make one yourself to hold the driven clutch half from turning.
MB
muleboy is offline   Reply With Quote
Just bought 86 Ninja 1000 in awesome shape 15k mls. starter just started misbehavin! johnpbrock Kawasaki Streetbikes/Sportbikes 10 07-24-2008 08:20 PM
Need help - trying to remove front brake Streaking Tiger The Mechanics Corner 3 11-11-2007 04:19 PM
bayou 220 starter problems possible reason elwood22165 Kawasaki ATV and Mule 1 02-22-2007 05:51 PM
Better way to get a starter out of a 600R (ZX600C5)??? c00lkatz The Mechanics Corner 2 04-27-2006 05:11 PM
Removing Starter Motor from '80 KZ440 bmilbrand The Mechanics Corner 0 07-09-2004 02:18 PM
