Old 09-12-2008   #1 (permalink)
Ohio dude
Ohio dude
Default 2003 Prairie 360 4x4
Won't Start......I have good spark.....blue and bright.....even tried new spark plug.......plug is getting enough gas.........even tried a little starting fluid on the plug.....nothing........quad has always started......
Where to look next?
Any and all help .....other web sites?
Ohio dude is offline   Reply With Quote
Old 09-12-2008   #2 (permalink)
86klf300guy
Can't find time to ride
86klf300guy's Avatar
hows the compression,and have your adjusted your valve lash lately?now the machine was running and then died out or just one day went to start it and no go?if it was running when died how was it running prior to dieing out?
Old 09-12-2008   #3 (permalink)
RCW
Wants better weather!
Check the woodruff key on the alternator flywheel. They sometimes strip and put the timing out in left field. A 35 cent fix.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
2005 Prairie 360 4x4 front differential fluid reddrt Kawasaki ATV and Mule 2 04-20-2008 10:17 PM
03 Prairie 360 4x4 question AwfulSmokey Kawasaki ATV and Mule 0 10-20-2007 01:00 AM
05' Prairie 360 4x4 problem TyW Kawasaki ATV and Mule 4 10-03-2007 07:48 PM
Prairie 360 belt and 4x4 lights on and Flashing scottw Kawasaki ATV and Mule 1 04-21-2007 04:26 PM
Vin # on 2003 Kaw 360 prarie 4x4 laketom Kawasaki ATV and Mule 2 11-04-2004 07:36 AM
