Old 09-24-2008   #1 (permalink)
bombe00722
Default 300 bayou 4x4 1992----oil problem
Hi, my motor oil is going into my rear differential, i've change the oil seal where's the drive-shaft connect to the motor, but always the same problem.And i've lost some power too.
Any idea of what is the problem???
bombe00722 is offline   Reply With Quote
Old 09-25-2008   #2 (permalink)
RCW
Wants better weather!
OK, so when you pop open the clamp on the drive shaft boot you are getting oil draining out in great quantities?
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 09-25-2008   #3 (permalink)
bombe00722
the oil is coming out when the motor runs, and it comes out by the end of the axles. the inside rims are full of motor oil...
Old 10-12-2008   #4 (permalink)
nmhuntr
I may have had a simular problem with my 92 Bayou 300. The oil level kept dropping and the boor that covers the joint just priot to going into the gear box was filing up. The problem was with the shaft not the seal. The inside of the shaft was worn out and the oil was going down through it. I got an new shaft and problem solved.
Hope it helps
nmhuntr is offline   Reply With Quote
1988 300 Bayou 4x4 Frt. driveshaft fb0226 Kawasaki ATV and Mule 0 08-05-2008 09:58 AM
300 Bayou problem minichopper Kawasaki ATV and Mule 1 04-27-2008 04:11 PM
Kawasaki bayou 300 4x4 Propeller Shaft needed Terry Bronke Kawasaki ATV and Mule 1 03-19-2008 11:31 AM
Bayou 300 4x4 B or C ? Tag Kawasaki ATV and Mule 1 01-04-2007 09:03 PM
