Old 10-07-2008   #1 (permalink)
Suz
Default Is 50% wear too much?
I have a 98 Mule 4x4. Repairman says both clutches are showing 50% wear. He thinks they should be replaced. I'm thinking 50% wear shouldn't mean worn out. Am I wrong? Shouldn't parts last more than 50%? What do you guys think?
PS I'm going to use RCW's Comet Clutch Lube in any case; maybe I'll luck out and give them another winter's life.
Suz is offline   Reply With Quote
Old 10-07-2008   #2 (permalink)
RCW
Wants better weather!
You really will not know until you inspect the clutches. 50% wear means nothing to me. Look for excessive looseness in the bushings, binding or rough rollers, grooves in the flyweights, missing or worn buttons in the driven clutch, grooves in the driven clutch helix, and roughness or wear grooves on the faces of the sheaves.
I use the rule that if I can wiggle any clutch component that should be snug and smooth to the corresponding pin or bushing, then it is too loose to run and time to replace that bushing or pin, or whatever. Grooves in the sheaves from belt wear can be minor or enough to cause the belt to hang during shifting. Roughness on the sheaves will ruin a good belt in no time.
The total cost of all the normal wearing parts is insignificant, the big bucks come in the sheaves if they are worn and causing problems. Labor is a big cost in rebuilding clutches, and can actually make it less expensive to simply replace the old unit(s).
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
RCW is online now   Reply With Quote
Old 10-07-2008   #3 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
To my thinking thats very worn out.
I rebuild a lot of clutches, and they need to kept in top shape.
Easy to do, so why not do it.
Riding is good for ones soul.
Riding amongst friends is even better.
Saleenguy is offline   Reply With Quote
Old 10-08-2008   #4 (permalink)
unit5alive
Made It To Second Gear
unit5alive's Avatar
Smile
I've used the Comet Clutch Lube in the past ,(on snowmobiles)with great results.
07 610camo,roof,f&rbumpers,storagebin,tach,speedo,flr mat,benz silent rider,hitch,turn signals,winch
unit5alive is offline   Reply With Quote
Old 10-08-2008   #5 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
Whats worn....the pins, bushings, slides, helix, or what?
If the pins and bushing are worn they flop around and bind, really screws up the backshift.
Old 10-08-2008   #6 (permalink)
kzlyle
'84 kz550f ltd
kzlyle's Avatar
if its not broke, don't fix it.
motorcyclists do it on the road !!
kzlyle is offline   Reply With Quote
Old 10-09-2008   #7 (permalink)
Ericthejet
Forensic Bug Splatter Analyst
Ericthejet's Avatar
What the mechanic is say is that you have 50% remaining to use.
Do you change tires on the a car/bike if they are half used?
Take a pass.
1984 Ninja 900 (A1)
To make it go faster I need to add more lightness!
Ericthejet is offline   Reply With Quote
Uneven disc wear on Vulcan 900 Matt7even Kawasaki Cruisers 5 06-23-2008 02:50 AM
Rear brake wear... eidian Main Lobby 8 12-18-2006 03:43 PM
Question: Better to wear prescripted glasses or wear contacts during riding? Lord U Main Lobby 21 08-18-2006 09:12 AM
Abnormal Cam Wear Found @ 1st Service... Rhapsody Kawasaki Touring and Sport Touring 8 02-14-2006 12:55 AM
What size Alpinestars jacket do YOU wear? SashaBelov Riding Gear 7 05-23-2005 10:52 PM
