Old 10-11-2008   #1 (permalink)
pididal77
Default at a loss of what to do about flooding 98 300 bayou
rebuilt carb original vacum piston and float, float dosnt leak vacum piston seems in good shape, was running, now it wont start backfires and spits fuel out the back of the carb spark plug is soaked in fuel, not sure if i have the right vacum line hooked up to the vacum piston using the line comming off of the top of the valve cover. and now I think i got the starter jet and the main jet mixed up, which one is which tow difernet size holes have tried both in both positions cant figure out why it is constantly running rich help please any input would help have clymer manual but dosnt seem to be helping . IM GOING MAD PLEASE HELP ps fuel seems to be puddling up at back of carb towards the air box
pididal77 is offline   Reply With Quote
Old 10-11-2008   #2 (permalink)
Ericthejet
Forensic Bug Splatter Analyst
Ericthejet's Avatar
Get a proper manual.
I don't think the same jet will fit in two different locations.
I think the vacuum line and fuel line are different sizes to prevent mixups.
Possibly you have what sounds like a sticking float, allowing gas to keep flowing into the carb.
Set fuel tap to "run" and gas should only flow once engine is running.
Again, get a manual or basic shop book.
1984 Ninja 900 (A1)
To make it go faster I need to add more lightness!
Ericthejet is offline   Reply With Quote
Old 10-11-2008   #3 (permalink)
pididal77
no, the vacuum line and fuel line are not mixed up when we got it the port for the vacuum line didnt have anything on it i saw a hose that comes from the top of the valve cover and it fits perfectly so i figured that's what's supposed to be there, but don't know and the two jets have different size jet holes but they are the same size so they fit in both holes in the carb
Old 10-12-2008   #4 (permalink)
fb0226
Shadetree Mech
fb0226's Avatar
Yes they will fit into either one. I have a trick that I have used for many years that did me wrong on mine so I have learned to look a little closer, I will take a "sharpie" and mark 1 jet and the tower it came out of. However that only works when the last person to mess with it (P/O) assembles it right. The larger goes with the needle. Also make sure the needle is installed right ( diaphram, needle, holder, spring, top). If that still doesn't help OR the next time you have it apart (whichever comes first) look on the inside of the bowl area and make sure one of the little brass plugs didn't get blown out (as I did on mine while cleaning it for the 30th time.....lol) ........ good luck
"I can fix anything......except stupidity"
1981 C B 750 Custom
1989 Bayou KLF 300 c 4x4
fb0226 is online now   Reply With Quote
Old 10-12-2008   #5 (permalink)
pididal77
thank you very much and as of right now that means my jets are backwards so i will be swapping them shortly...what do you mean little brass plugs???
Old 10-12-2008   #6 (permalink)
fb0226
Shadetree Mech
fb0226's Avatar
Attachment 23914
note: the plug in the lower left corner/ and the one missing at the pointer
this blew out with about 60 psi. trying to blow out all the passages
1981 C B 750 Custom
Old 10-12-2008   #7 (permalink)
86klf300guy
Can't find time to ride
86klf300guy's Avatar
hello ,well on the carb rebuild did you take the air fuel mix screw out?the screw with the spring on it and the screw has a pointy needle at the end of it.if so there is a rubber washer that is suppose to be in that screw assy if that little oring is mia or the pointy part of that screw is mia that would cause over fuelin alsoand if everything is ok with the screw then is it adjusted out 1 1/2 turns out from seat if it is all the way tight and not backed out that is just all fuel and no air as for the vac hose i think the one off the top of the engine is left off for a crank case breather only and the one port at the top of the carb is a breather for the carb the vacuum comes from intake of the carb only while the motor runs it pulls vacuum through the carb and the 2 holes that face the motor in the carb goes to the vacuum diophram in the carb something like that ne who but the port on the top of the carb should have just a hose that hangs down to the float bowl..and one more question hows the compression and the spark look?are you gettin a good spark out of the plug?-corey-
91 bayou 300 4x4 rear diff problems ty95daniel The Mechanics Corner 2 07-11-2008 05:19 AM
Bayou 300 CDI, Regulator, & Carb SteveS Offroad Buy/Sell/Trade 2 05-16-2008 11:20 PM
300 bayou flooding deerhunter The Mechanics Corner 2 08-27-2007 12:56 PM
need bayou 300 rear diff help ty95daniel Kawasaki ATV and Mule 0 07-05-2006 10:10 AM
Replacement starter relay/solenoid therealSnafoo The Mechanics Corner 13 04-04-2006 10:02 AM
