Never quite fixed.
I'm sure you could, with a little modification to the battery tray. I don't know much about mules so I can't help a lot, but it might involve fabricating a new tray.
What is your reasoning behind a bigger battery? |
#6 (permalink) |
Way Too Much Free Time
I frankly think the OEM 610 batteries should be replaced for two reasons. The plates shed lead from the vibration and bouncing of the Mule, so the battery loses a great deal of its capacity in a very short time. The batteries are simply too small for the kind of use a Mule receives and must be kept on a desulphator type maintainer/charger when idle, or they permanently lose 60% of their capacity in just a few weeks.
There are two alternatives, go to the site sponsor, or to Batterystuff.com if they do not have one, and get one of their higher capacity AGM type substitutes, or modify the battery holder to use an Optima Red Top automotive battery. My preferred solution is to use the Optima Red Top automotive battery, but it takes a bit of modification. You have to make the battery holder larger to fit the Optima, but the Optima can be mounted on its side and not leak or be adversely impacted by vibration. I you have a reasonable set of skills, pull the passenger seat and measure the space really available with some slight modification to the compartment. The metal needed to make the modifications is readily available from places like Lowes, and can be handled with a sawsall and a metal cutting blade. Then make a new battery box, and install the Optima - that is all I use. You will not regret that decision. I have Optima's still in service on diesel tractors that were the very first Optima batteries commercially available, and they are going strong years and years later. The Optima is completely vibration resistant, and will never corrode the terminals or eat through the battery box.
2008 3010 Trans4X4 Diesel Mule 2008 JD XUV 850 Diesel 1979 XS650 Yamaha New DR-Z400S |
#7 (permalink) |
that optima battery ie the best you pay a little more now but youll save a lot in the long run they are the toughest batterys made like rcw said you can lay on its side and it will not hurt this battery and vibrations ha nothing will hurt this type battery.try layin a normal battery on its side it doesnt end well.so if you have some fabrication skills or know sumone that does this will definitly make a big differece....see i said rcw will have the answer for this sounds like he been around the block wonce er twice with these machines ---corey-
| No spark on a zx750 pls pls pls help | MR.S7 | The Mechanics Corner | 59 | 05-19-2009 12:41 PM |
| Types of motorcycle / auto battery | Mercury | Main Lobby | 5 | 06-22-2008 01:12 PM |
| 83 Suzuki 450L not starting | rugger1 | The Mechanics Corner | 11 | 05-30-2008 12:21 PM |
| Start with the basics, the battery is the life blood. | tttjump | What I learned today | 4 | 03-16-2008 02:48 PM |
| VN900LT Electrical Problems or just bad battery? | Roscoe75 | Kawasaki Cruisers | 17 | 05-12-2007 11:03 PM |
