Old 11-17-2008   #1 (permalink)
Hammer9
Default 02 Prairie Not Firing?
This is a project bike but everything seems to be fine on it! It cranks over, has spark, smells like its getting fuel but no firing. If i leave the throttle open for just a couple of seconds it will back fire a little bit. Does anyone have any ideas on what it could be or what to try?
Hammer9 is offline   Reply With Quote
Old 11-17-2008   #2 (permalink)
86klf300guy
Way Too Much Free Time
86klf300guy's Avatar
hello well first id check compression ,if it is low it will not generate enough pressure to make a boom, if the compression is over 120 then id ajust the valve lash, maybe the valves are hangin open just a bit to much, this would cause low comp also. but i suspect maybe the timing is off a bit-corey-
Old 11-19-2008   #3 (permalink)
Hammer9
It very well could be the timing! I tried to set it but couldn't find the TB or TF marks on the generator. Is there another way to set the timing or do you have to go by those marks. I set both sides at full compression when I did it. Do you need a special tool to check compression? Thanks for your help you guys are awesome!
Old 11-19-2008   #4 (permalink)
86klf300guy
yea, you need to go bye the tester gauge itll come with adapters to fit your plug thread. itll run like 30 -100 depnding on what kit you get ,and you may have to get some cleaner and clean the fly wheel off due to grud build up. the marks are stamped on the flywheel, just dirt etc builds up and fills those marke in and make it a pain to see em.non choleanted brake parts cleaner will do nicely,for it does not leave a film on the parts -corey-
Old 11-19-2008   #5 (permalink)
fb0226
Shadetree Mech
fb0226's Avatar
Originally Posted by 86klf300guy View Post
yea you need to go bye the tester gauge itll come with adapters to fit your plug thread itll run like 30 -100 depnding on what kit you kit and you may have to get some cleaner and clean the gen off of it grud build up itll be on there -corey-
If you have a Harbor freight tools store near you, you can get one there for 15-20.00
"I can fix anything......except stupidity"
1981 C B 750 Custom
1989 Bayou KLF 300 c 4x4
fb0226 is offline   Reply With Quote
Old 11-19-2008   #6 (permalink)
86klf300guy
dang thats cheap! i wish i knew about this place before i bought the hole kit form snap-on.it costed me 150.00$ for the hole kit.but i can test all motors,even weed whippers lol.now i am goin out back and hang my self .....nah ill just kick my self instead...corey
Kawasaki prairie 300 1999 mag wheel help reisset Kawasaki ATV and Mule 0 11-06-2008 10:09 AM
one cylinder not firing jneaves The Mechanics Corner 13 08-28-2007 04:14 PM
650 Prairie Popping and Back firing, Limp Mode reset? John Stachowski Kawasaki ATV and Mule 1 11-28-2006 11:40 PM
97 Prairie 400 4x4 damper in drive system 4chnit1 Kawasaki ATV and Mule 2 11-11-2006 12:34 PM
Prairie 650 Valve adjustment TrailBuster Kawasaki ATV and Mule 2 07-28-2005 02:41 PM
