I miss Deron.
![]() ![]() Join Date: Dec 2004
Welcome mate! Glad to have you join us!
I moved your thread over here to the ATV section where you're more likely to get some help. Someone should be along shortly. Ride safe & post often!!
LIGHT ENGINEER Todd's Body Paint Team Black 1600w/apes aka Scooter |
#4 (permalink) |
I just picked up my wifes 08 360 prarie from the shop,4 x 4 light flashing still under warrenty. Depends on the flash timing ( number of times between flashes) according to the dealer and the manual. It is either the EBC electronic brake control / 4 wheel drive solenoid or the brain. According to my mechanic it could be caused by something as simple as dirt in the actuator mechanism. If the 4 x 4 engages it is most likely not the front actuator but the engine brake controller. I can never get it to recreate itself at the dealers, But if I disconnect the battery it goes away and may take a month to come back. I don't know how comfortable you are working on your own, but if you can get a service manual it walks you through all the steps to check out the actuators with a volt meter, mine turned out to be the EBC it was just sticking. This should help you pinpoint exactly what the problam is.
#6 (permalink) |
Ours didn't matter if it was hot or cold. If we had stopped say for something to eat and a cold one, it may start flashing as soon as it was started up again. I could never realy get it to repeat under a certain condition. It definetly had a mind of its own. So to be honest I have no idea if bike temp has anything to do with it.
| 03 650 prairie belt light? | 03s281sc | Kawasaki ATV and Mule | 3 | 11-23-2008 06:34 PM |
| top end bogging prairie 360 4x4 | mudseeker | Kawasaki ATV and Mule | 3 | 09-11-2008 09:02 PM |
| oil light flashing 650 v-twin | mike72 | Kawasaki ATV and Mule | 0 | 06-12-2005 03:13 PM |
| 03 Prairie 360 4X4 Belt Fault Switch | jlively | Kawasaki ATV and Mule | 2 | 10-25-2004 06:27 AM |
| flashing brake light bulb??????? | okbow68 | Kawasaki Cruisers | 12 | 06-17-2004 05:23 PM |
