changing rear wheel bearings 2510 mule
+ Reply to Thread
Results 1 to 2 of 2
Thread: changing rear wheel bearings 2510 mule
  1. #1
    Join Date
    Nov 2008
    Posts
    1
    Default changing rear wheel bearings 2510 mule
    what to take apart to change rear bearings
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    RCW
    RCW is offline
    Needs A Real Job BTK Expert
    Join Date
    Nov 2007
    Location
    Oregon, Chile, Alberta, Texas
    Posts
    3,781
    Follow the procedure for removing the rear driveshafts, as you need them out of the way before you start on the bearings.
    Then you use a drift and drive the inside oil seal and bearing out of axle support of the rear suspension bracket toward the inside of the housing, then remove the collar from the outside of the same and drive the outside bearing out from the inside.
    If you do not have the repair manual, this is a good time to get one as you will need it for the torque values, etc.
    If toys will get me in the door when it is time to go, I have it made!
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. WANTED: 16 inch rear wheel (complete) from CSR
    By KCMC in forum Accessory Swap Meet
    Last Post: 06-08-2006, 09:17 AM
  2. mule 2510 crank bearings
    By ssmule in forum Kawasaki ATV and Mule
    Last Post: 11-30-2005, 05:12 PM
  3. rear wheel, swingarm, rear caliper changeout
    By pianoplayer in forum Main Lobby
    Last Post: 07-18-2004, 10:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
