Old 01-02-2009   #1 (permalink)
scott1963
Default grease or never seize on splines
i am getting ready to put the rear end back into my 2510 4x4( replaced both sides bearings and brakes and was wondering what everybody uses to grease the splines on the axles? Also i am getting ready to replace all of the u-joints on the drive shafts and hope that they take the same grease or ?
thanks
scott1963 is offline   Reply With Quote
Old 01-03-2009   #2 (permalink)
RCW
Way Too Much Free Time
Use a non-clay based grease. Shell Aeromax, any Hydrotex product, and Lubriplate Syn-1600 series greases are non-clay based. The Hydrotex greases are the best, as they inhibit rust.
Regular automotive grade greases are mixtures of Bentonite clay, water, and oil. Some have moly added to help with lubrication when it starts to dry, but any clay in the mix is what does the damage. The oil dries out, the clay attracts more water, and becomes a fine abrasive that will walk out the splines over time.
In years gone by I used nickel based antisieze, but it has become priced out of sight. Do not use the antiseize for nuts and bolts, as it contains microscopic glass balls and will grind out the splines.
I grease my splines every year to keep them from rusting and wallowing out.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
Old 01-04-2009   #3 (permalink)
scott1963
Thank you for the reply. Do you know where the best places are to find Hydrotex products?
Rocker arm grease nipple TimB Kawasaki Cruisers 96 10-01-2009 01:24 AM
Grease on Wheel Hub jdpenn Kawasaki Cruisers 7 12-22-2006 10:52 PM
Greasing the rear splines on 04 Vulcan 750 AMH Kawasaki Cruisers 0 09-24-2006 10:08 PM
Grease in right side air box... ?! deniska Kawasaki Cruisers 8 03-28-2006 05:09 AM
Grease under bike!! ZX6RRNewbie The Mechanics Corner 5 10-01-2004 12:32 AM
