Old 01-13-2009   #1 (permalink)
cwilliams
Default Bad plug
I found it was a bad spark plug
cwilliams is offline   Reply With Quote
Old 01-14-2009   #2 (permalink)
unit5alive
Mule 610 pilot
unit5alive's Avatar
Arrow
You need to tell us the year ,model , and what engine it has, to get a little more help.
07 610camo,roof,bumpers,,tach,spdo,flr mat,benz silent rider,hitch,turn signals,winch,stereo 4 spkrs
unit5alive is offline   Reply With Quote
Old 01-14-2009   #3 (permalink)
cwilliams
Old 01-14-2009   #4 (permalink)
RCW
Way Too Much Free Time
If you are running on one cylinder it is likely either a pulsing coil (they are replaced as a pair), an ignition coil, the valves are loose on the missing cylinder, or you have a bad plug.
The wiring harness on these is such that if power is to one coil, it will also be to the other coil.
I really recommend you purchase the service and repair manual. These rigs are just about bulletproof if they are properly maintained. But, without the book it is easy to nuke the Igniter by grounding an excited wire by accident, or by grinding on the starter with the plug wires disconnected.
The cost of a new Igniter could buy you many service and repair manuals.
2008 JD XUV 850 Diesel
1979 XS650 Yamaha
New DR-Z400S
RCW is online now   Reply With Quote
Old 01-14-2009   #5 (permalink)
cwilliams
Interestingly enough and thank you for your reply, I checked the pickup coils and had trouble getting a reading, and then tried a little more only to see a lot of corrosion on the terminals, so maybe my test of the igniter is wrong and a failed pickup coil is stopping the second coil from sparking, either way I will test it tomorrow after cleaning the terminals. I really need to replace the entire harness, but I did solidly repair the many cuts I had so those are good, so if this fixes it and things are good, I will then go back and do the harness. I would be thrilled if it wasn't the coil. Thanks for the help I will let you know.
I am still amazed that this machine ran so well just one one cylinder so it will be nice to see it running on 2!
1995 EN500 Cylinder Gasket - Replace? climb_eng The Mechanics Corner 3 02-07-2008 07:08 PM
A new Cylinder? YurFatMom Kawasaki Motocross and Offroad 21 03-31-2007 11:29 AM
95' KX 100 running extremely rich... 2stroke173 Kawasaki Motocross and Offroad 2 03-23-2007 03:11 PM
Advice needed, running on 3 cylinders flame220 The Mechanics Corner 2 07-31-2006 02:18 PM
Trouble with one cylinder druk The Mechanics Corner 8 01-11-2004 08:02 PM
