2510 drive converter question
+ Reply to Thread
Results 1 to 3 of 3
Thread: 2510 drive converter question
  1. #1
    Join Date
    Jan 2009
    Location
    tuscaloosa,alabama
    Posts
    10
    Default 2510 drive converter question
    I just finished disassembling , cleaning up and spraying clutch lubricant on the parts that called for it and putting it all back together and reinstalling it. I have a question about the drive convereter cover assembly. There is a beveled ring that looks like it is suppose to fit in the hole of the cover assembly and slide over the sleeve that the spring sits on. My question is, is the sleeve and the beveled ring( when it goes throught the cover assembly ) suppose to be a close fit or is there suppose to be a good bit of slack. Mine has slack in it and when you give it a little gas, it start to flop right there. When you give it full throttle, it smooths out and when you let off of the gas all the way it stops.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Join Date
    Aug 2009
    Posts
    3
    I have the same problem. If you figured it out , please let me know.
    Thanks Steve
  4. #3
    RCW
    RCW is offline
    Needs A Real Job BTK Expert
    Join Date
    Nov 2007
    Location
    Oregon, Chile, Alberta, Texas
    Posts
    3,781
    Go to Kawasaki.com and the parts diagrams, then let me know which part number and component the ring is listed under. I am completely unaware of anything that should be flopping around under normal circumstances.
    If it is the sleeve that rides in the cover bushing, that should be a sliding but snug fit if the bushing and sleeve are in good shape.
    If toys will get me in the door when it is time to go, I have it made!
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Gasp!! A Newbie Noise Question!
    By PopJack in forum Kawasaki Cruisers
    Last Post: 10-14-2007, 07:08 PM
  2. Flash Drive Question
    By RampRat in forum Off Topic
    Last Post: 04-01-2007, 10:22 PM
  3. Speaking of Calendar Proofs....
    By LordGT in forum Main Lobby
    Last Post: 12-07-2006, 05:55 PM
  4. Drive Ratio Question
    By scubbersteve in forum The Mechanics Corner
    Last Post: 02-05-2004, 07:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
