Old 05-16-2005   #1 (permalink)
610dog
Banned
Default Hp Mule Parts???
does anybody make/sell aftermarket stuff (exhaust, big bore/stroker kit, etc)to give the 610 more grunt, or am I going to have to do it myself (ie stick another motor in/whatever)?
and no, don't even think about recommending talking to my dealer (AV KAWASAKI), they couldn't even put on the accessories I've already installed...
610dog is offline   Reply With Quote
Old 05-31-2005   #2 (permalink)
desertmule
MULEABUSER
desertmule's Avatar
i've had mine for a month now and i can't find anything either...i'll get bigger tires first...how do you like the fit of the 25's?...i'm going to try 27's...are you sure you can hit 35 mph...my gps says 25 mph on the flats...i'm looking for cdi's now...i've heard suzuki eiger uses same motor...stock mule is about 14 hp..timing is 20 deg constant which is a little retarded for an 8.5/1 comp. motor.....write if you find anything...i'll do the same...every forum i've been on for these mules is like a ghost town...
desertmule is offline   Reply With Quote
Old 06-01-2005   #3 (permalink)
Kawi
Proud Owner Of This Forum
Kawi's Avatar
Smile
Gentlemen I fell your pain on the mods however I feel the need after reading some posts by 610dog to offer some insight into the new and I repeat very new mule. The KAF400A1 or better known as the 610 4x4 by Kawasaki is a Utility vehicle and I hope your dealers told you that when they sold it to you. Kawasaki was the flag ship for the Mule Utility many years ago. It was designed to be a work horse and by no means a RV. They are 401cc belt driven Utility which is a huge improvment over the previous 550 model with 286cc. They are designed for light duty utility work such as around an apartment complex, construction sites, etc. The ATV saftey council has a reported 88 cases of accidents already with some of the Mule knock off's that insist on making it an RV at 40+ mph which is why you won't see Kawasaki go above 25mph. The accessories for the Mule 600 and 610 as well as the new 3010 Trans won't be available till late summer because it is a totally new design. All cab accessories are built by Curtis Tractor Cabs and the rest are developed by Kawasaki. Even though there are a few accessories that dealers know about even those are on back order right now.
Let me just add the belt squeal 610dog is hearing is most likely caused by the over sized tires and loads beyond the recommended limits, the cure is to adjust the belt deflection.As far as the alternator it sounds to me like the sound system you are running would require the Heavy duty alternator only available on the 3000 series and is stock on the 3010 diesel. I don't want to discourage you gentlemen however I think it is only fair to tell you that what you want this machine to do may turn out to be a disappointment for you.Don't forget some of those mods can void your 1 year warranty so be careful.
Kawi is online now   Reply With Quote
Old 06-01-2005   #4 (permalink)
desertmule
MULEABUSER
desertmule's Avatar
hey kawi,
thanks for your input...i will admit that this was an un-reasearched decision for me...i know the 610 is no speed demon..i'm trying to attain 30-35 tops on the flats...i'm very disappointed with the dealer..he is a kawi/yamaha dealer in pahrump,NV..i am 35 years old and i specifically explained my intentions for this vehicle.. i wanted something i could take my kids trail riding on and have some fun too...never a mention of a need for a work horse...he should have recommended a rhino but, he didn't have one in stock so he sold me the mule without mention of the rhino..i'm not going to bash my little buggy..i think the 610 is a pretty cool ride...it is fun and can climb through some pretty rough stuff..if i can get a little more speed for some of the long dirt trails i ride, i'll be happy...i jumped in without knowing what i was buying and what else was available....just trying to make the best of it...
Old 06-01-2005   #5 (permalink)
desertmule
MULEABUSER
desertmule's Avatar
hey kawi,
one more thing...do you know if a speedo and tach will be available for the 610?...
thanks,
william
on edit: and a service manual for 05 610...
Old 06-01-2005   #6 (permalink)
Kawi
Kawi's Avatar
Even though we don't show a speedo yet I am almost certain you will see one however the tach I am not sure of.
Old 06-02-2005   #7 (permalink)
desertmule
MULEABUSER
desertmule's Avatar
hey kawi,
how about the service manual for the 05 mule 610?..is one available..
thanks again,
william
Old 06-02-2005   #8 (permalink)
Kawi
Kawi's Avatar
Smile
99924-1349-01 Thats the part number for the service manual $59.95 is list price your price is $53.95. If you want to order it call Lauri at 1-800-556-3098
Old 06-09-2005   #9 (permalink)
desertmule
MULEABUSER
desertmule's Avatar
thanks guys,
manual ordered...can't wait for 610 accessories to come out...
Old 08-22-2006   #10 (permalink)
610dog
Banned
25's fit fine, no issues. wouldn't go larger w/out a lift kit and more power/different gearing though. in that regard, I did find out that (alledgedly), we can use the crank, rod piston, cam and head from a cousin 400cc kawi (forgot which model), but there's also a big bore kit that may work/be even better. haven't bothered w/it lately, as it seems ok, kinda... but a torque improving pipe would probably be a good start... now that the warrenty is up, as stuff blows/breaks I'll just upgrade to whatever makes sense at the time... been some good deals on kawi H2 motors lately, hehehe...
could just do some porting and mess w/the carb and ignition like you noted too, but I think more grunt would be best, and bigger ports/more revs will only help top end, so increased displacement seems to be the best way to go, on one of these IMO.
spedo?? I just read about someone that finally got one last month glad I didn't wait for the rest of the stuff and just had it fabbed up instead...
bout as maxed out as it can get w/out going nuts for one of these (rhinos do have a LOT more accessories for sure).
35mph was on a LONG flat, perhaps slight downhill w/a tailwind... larger tires and tweaking the govenor probably helped a tad too, but on any kind of uphill or against the wind run it's lucky to hit 25-30... seems fine for most of the riding I do, and like kawi noted, the "high speed" handling on these types of vehicles sucks - so I'd guess 35-40 is kinda pushing common sense anyway. wouldn't want to spill my beer
regards!
Old 08-25-2006   #11 (permalink)
desertmule
MULEABUSER
desertmule's Avatar
hey 610dog,
that was me that got the speedo last month...only on backorder for a year...
if you know anything else about the "other" rotating assy and cam let me know..
you actually went UP a hill going 25?LOL
