Old 03-08-2009   #1 (permalink)
h2o
The 717
h2o's Avatar
Default Dumb question
This may seem dumb but I need to ask. I already did a search and didn't find what I need. I want to put a horizontal side mount license plate on my 900 custom. I started to spin the rear axle nut with a 22mm socket but it spins slow and doesn't seem to be getting loose. I stopped because I didn't want to damage anything if I was doing it wrong. Is this normal? Am I doing it the wrong way? Once I do get the axle nut off, will there be enough room left to get the plate on? It doesn't seem like it. Thanks in advance for any responses.
08 900 Custom
Travis
h2o is offline   Reply With Quote
Old 03-08-2009   #2 (permalink)
metallisch
all things metal.
metallisch's Avatar
If you're trying to loosen the nut off, are you making sure that the axle bolt head is not spinning with it at the same time?
When in doubt, I usually give a trouble nut like that a little blip with the air impact. That usually has enough juice to break loose a stubborn nut that just wants to spin like you described. I do that with fork bolts all the time.
As for clearance for the tag bracket, I would suggest just trying it out. I've definitely seen it done, but to me the axle doesn't seem like an ideal place. Being that you don't exactly have shock bolts to use though, I'd say it is your best bet, but you already knew that.
At night we ride through mansions of glory in suicide machines
metallisch is offline   Reply With Quote
Old 03-08-2009   #3 (permalink)
h2o
The 717
h2o's Avatar
When I turn, the nut is the only thing spinning.
08 900 Custom
Travis
Old 03-08-2009   #4 (permalink)
vulcan01
check your pm
vulcan01 is offline   Reply With Quote
Old 03-08-2009   #5 (permalink)
Turtle47
Hoosier Vet
Turtle47's Avatar
The axle is like a big long bolt that goes all the way thru the wheel. Yo have to put a wrench on the bolt head on the left side of the bike, then loosen the nut on the right side. The one you took the cotter key out of .Right? You did take the cotter key out? Don't want to appear to be an a$$hole here, but I have seen people do this.
Turtle47 is offline   Reply With Quote
Old 03-08-2009   #6 (permalink)
pat0021
IBA#34418
pat0021's Avatar
Send a message via Yahoo to pat0021
same thing I was thinking. If you don't look on that side you won't know there is a pin to take out. But you still need to use 2 wrenches. You'll also need to loosen the rear wheel adjusters and slide the wheel forward. Mark where they are first so you can put them back easily.
If you like your freedom thank a Vet!
U.S. Navy Vet
2006 VN900LT
pat0021 is offline   Reply With Quote
Old 03-08-2009   #7 (permalink)
h2o
The 717
h2o's Avatar
Ok so now it's apparent that I have no idea what I was doing. I wasn't even thinking about the other side. So I really look dumb now. Do you think I can mount a plate on this bolt?
08 900 Custom
Travis
Old 03-08-2009   #8 (permalink)
pat0021
IBA#34418
pat0021's Avatar
I wouldn't call you dumb. Easy to miss stuff when you're not looking for it. But the best suggestion I could offer is to shop around for side plates and see how they are supposed to be mounted. Without going out and looking at my rear wheel I am not sure how much stud is left on that side to mount anything.
U.S. Navy Vet
2006 VN900LT
Old 03-08-2009   #9 (permalink)
h2o
The 717
h2o's Avatar
That's what I'm worried about. I think I'm going to take your advice.
08 900 Custom
Travis
Old 03-08-2009   #10 (permalink)
pat0021
IBA#34418
pat0021's Avatar
be sure to take pics for us when you put something on.
U.S. Navy Vet
2006 VN900LT
This may be a dumb Question??? nomadfool Kawasaki Streetbikes/Sportbikes 2 11-10-2008 10:28 PM
This maybe a dumb highway peg question...but Fitz1973 Kawasaki Cruisers 8 09-14-2008 07:56 PM
Dumb question about headlamps jukief The Mechanics Corner 26 01-26-2008 08:02 PM
another dumb question on pinging... su1kil Kawasaki Cruisers 53 03-21-2007 11:29 PM
Dumb question about power outlets jukief Kawasaki Cruisers 5 01-24-2007 10:39 AM
