LinkBack | Thread Tools |
Foil Inspector
Hi Everyone
I have a few quick questions. 1) What is the highest speed which is comfortable for the Vtwin ? 2) Im getting a slight low noise coming from the gas tank cap which looks as if the air is trying to rush out. Any solutions ? Im using premium gas 3) Do the windshield lowers of a vulcan 2000 fit the 800 classic ? Thanks in advance Agnelo |
#2 (permalink) | |
Go Hogs!!
Foil Inspector
Thanks for the reply. Well Im lost now
About the whistle from the cap, can I adjust the spring easily ? Can I directly change to the Regular gas next time I visit a gas station or is there a procedure to do so ? I've been hearing about seafoam but not sure where to get it from & how to use it. help pls Agnelo |
#4 (permalink) |
Can't find time to ride
Get Sea Foam at NAPA Auto Supply or what ever major auto supply is around your hood. Go to www.gadgetjq.com to fix the whistle. Cant help about the lowers.
#5 (permalink) |
The 18/40 set up Woody was talking about is the front and rear sprockets. The 800's come stock with front sprocket-17 tooth, rear sprocket-42 tooth. Going bigger on the front lowers the RPM's and going smaller on the rear will lower RPM's also.
I have changed just the front to the 18 tooth and could tell a difference at cruising speeds, now i'm considering changing the rear to the 40 tooth too. Just start using regular the next time you fill up. I have seen seafoam at local auto parts stores, and have heard that NAPA carries it too. You can just add some to the gas tank. Last edited by rwrighter : 06-06-2005 at 11:51 PM. |
#6 (permalink) |
Clutch Cadet
Welcome to the forum Agnelo. Just as the other guys stated, changing the gearing of the bike helps alot. I also have just changed the front sprocket and am considering changing the rear. You can order the sprockets through Sprocket Specialist. All I can tell you is that the front 18 tooth sprocket is about $20 and it helps alot. Also, just run the 87 octane fuel. Theres no change in performance and it will save you some cash for other goodies. Hope you enjoy the forum.
2004 Kawasaki Vulcan 800A Vance & Hines Straight Shots K&N Filter Saddle Bags Passenger backrest |
#7 (permalink) |
the "fun old" guy
Hi Angelo and welcome!
Did someone say SeaFoam? Good stuff Maynard. Get it at Napa Auto Parts stores around here. http://www.seafoamsales.com/motorTuneUp.htm ![]() |
#8 (permalink) |
Top Gear Full Throttle
I have cruised 80-85 on the highway with the stock gearing it will run all day at that speed. But it is smoother with the stock gearing changed, I run a 38 tooth rear sprocket that helped lower the rpms and it doesn't rev as much at highway speeds. A must do modification in my opinion.
I run 87 octane no sense to run anything higher the motor was designed to run on 87. As for the lowers they seem to be made bike specific, usually all add-ons are bike specific in they way they mount to the bike. I would say that the 2000 lowers would not go on the 800.
2004 800 Vulcan Classic Cobra backrest Cobra floorboards Mustang Daytripper seat |
#10 (permalink) | |
Go Hogs!!
#11 (permalink) | |
Don't get the big head Woody....LOL.. I don't brown nose often. |
#12 (permalink) |
Foil Inspector
Woody is indeed an asset to this forum & this I can say despite of my very less time I have spend in this forum, He has not only replied to most of my questions but it has been very prompt..
Thanks Woody & not forgetting all the others who help so much at the same time. Agnelo |
#13 (permalink) |
Cruising In Fourth Gear
You're talking to the right people about the 800's!
I have not done the sprocket change on mine, but I can tell by the way the bike feels at 65+, I'll probably do it. Whereabouts in Michigan are you located?
05 Brute Force 650 Warn 2.5 Winch Warn plow Moose racing receiver hitch |
#16 (permalink) | |
Go Hogs!!
#17 (permalink) | |
UBER CLUB MEMBER #2
![]() Join Date: Jan 2005
#18 (permalink) |
Foil Inspector
BTW, are there any long rides planned anywhere ? The other day I saw 107 ( I counted maybe incorrect ) Harleys motorcade passing through Farmington Hills in Michigan, a lot of noise for around 2-3 mins Where is the Montana trip starting from & when, I do want to visit Montana sometime this year to meet a family. Agnelo |
