Old 05-09-2009   #1 (permalink)
patrick17745
Patriot Guard Rider
patrick17745's Avatar
Default confusion about shocks
I am trying to set the shocks on my 99 Nomad. Going by the book they say not to use more than 71 psi or you could damage the seals. I set the regulator on my compressor for 65psi pumped them up then when I checked the shocks they only had 40 psi in them. Then I set for 71psi and still only showed 40psi.
What gives? Is there something I am missing here? Is there a trick to air them? Should my passenger be on when I air them?
Thanks
1999 Vulcan 1500 Nomad
patrick17745 is offline   Reply With Quote
Old 05-09-2009   #2 (permalink)
Guido
Patriot Guard Rider
Guido's Avatar
I'm guessing that you are losing air when you you remove the fill hose, and when you check them with a gauge. These air bladders are very small, so the air lose when checking the pressure can be a lot. You should look into getting a zero loss pump from Progressive. It has a gauge mounted on it and works like a bicycle pump. Also check out Gadget's main site for more info on other things. Lot's of good stuff!
FAQ's
Progressive Suspension Gauge Mounted Air Pump - Motorcycle Air Pumps - CBXManMotorcycles.com
They may be cheaper somewhere else, but this gives you an idea of what your looking for.
06 1500 Classic Anniversary
Guido is offline   Reply With Quote
Old 05-09-2009   #3 (permalink)
streak07
wisdom is IQ, not post #
streak07's Avatar
Supposed to use a zero loss pump. You'll never get it set or even between the sides with a standard compressor. You're also very likely to destroy them due to the pressures the compressors use.
streak07 is offline   Reply With Quote
Old 05-10-2009   #4 (permalink)
patrick17745
Patriot Guard Rider
Thanks I'll look into a zero loss pump.
I just figured if I set the regulator on the compressor to 60psi it would only let 60psi into the shocks.
Questions on Shocks? Klhender The Mechanics Corner 6 10-22-2008 01:27 AM
Progressive shocks for the V2K V2KCruiser Kawasaki Cruisers 11 07-10-2008 06:29 AM
Changing shocks without lifting rear of the bike is not a good idea eagle33 What I learned today 1 06-16-2008 12:23 PM
84 kx125 shocks dirtrider596979 Kawasaki Motocross and Offroad 3 03-31-2008 06:43 PM
nomad shocks on a vulcan nhparrot Kawasaki Cruisers 1 01-15-2007 11:31 AM
