LinkBack | Thread Tools |
I have a cherry vn740 withe 7k miles and a single cylendar is stuck. It's a 94 TEAL beauty. I don't want another bike.
Problem is, dealer service manager clearly doesn't want to work on it. I brought it in to clear up some valve noise heard while idling last summer, and asked why it was using oil. He said the engine wasn't even broke in yet. He said drive the "urine" out if it and bring it back in the fall. 400 miles later, no more oil usage. Hurray. 150 miles later the engine stopped. Left rear spark plug was toasted and almost no oil left. The next morning the bike started normally and ran at idle for 6 seconds. Then the cylender seized. The dealer says 1400 just to look at it and no guarentee it won't cost 4k plus. Service manager says, Buy a "new bike". I say no. He says buy a new engine then. He says it will cost nearly the cost of a "new bike". Then his vulcan expert said it will cost 4k for the brand new motor from Kawasaki and 2k to install. THEY sent me to Parts who said KAWASAKI doesn't even sell new vn750 engines. There ought to be some censureship for a dealer who won't perform maintenance you need when your next in line. This is a multibrand dealer and the vn750 expert is also the Honda Goldwing Expert. It's not economical for them to help ME unless it's snowing............ Recommend me an honest dealer who wants to see happy customers with bikes on the road, in the summer time, and at reasonable prices. Shoot, the cylendar's are sleeved. New Parts will cost $200 per cylendar. Thanks, from SW Missouri I think it's the cylendar because the starter wont turn the engine over at all though it really tries AND when in first gear and the engine off you cant roll it more than 6 inches in either direction. With the plugs out and Mystery oil shot in the plug holes, you can hear the sucking sound made by moving pistons, or piston, but they or it moves move only just a bit. The movement is enough so the mystery oil shoots out the front cylender spark plug sockets when I try to roll the bike, but not the back. Last edited by Lordc55 : 06-08-2005 at 06:28 PM. Reason: additional info |
Rebel Rider
You started it up with almost no oil in it??? Search for a used motorcycle parts supplier and pick up a used engine or look for one on ebay.
..... bluestringer 2005 Vulcan 1500 Classic FI V&H Longshots VROC #13910 GAVROC #159 |
Yes it was dumb. It was early ans I was just sick. I thought the oil probllem was solved and that the problem was due ti the reinstoem and moisture in the carbs. Ebay has nothing. There are no mentions of engiones available anywhere. One Junk dealer with 1k bikes in his yard has had only ONE vn750, ever. It was a 1993 thet was junked because the cams were damaged last year. He and the owner looked for months with no luck, using all available resources. It's funny, but he thinks the VN 750 is is not a very popular bike......... I wonder where they all go?
#5 (permalink) |
Cruising In Fourth Gear
Check out "Road Track and Trail" in Wisconsin. Go to www.CycleTrader.com and do a dealer search. This place has hundreds and hundreds of used bikes. They always have a handful of VN750's in stock it seems...the motor are the same regardless of the year I believe. When I was searching for used bikes, they always had low mileage VN750's for pretty good prices. If you want to keep your bike so desperately, buy a complete used one for around $2k and swap motors and you'll still have a clean parts bike on hand for any other needs that might pop up. Probably about your only choice unless you get very lucky. Either way, it's going to cost you money so you'd better be really commited to that bike. For under $6k, you can get a new VN750...your gonna probably spend $3k on this current bike and you'll never recoupe any of it, nor can you guarantee success, even after spending the money. You've already missed a lot of riding time, how much is it all worth?
And even an honest dealer can't guarantee it will be a cheap fix until they open her up first.
05 Brute Force 650 Warn 2.5 Winch Warn plow Moose racing receiver hitch |
#6 (permalink) |
RIP Deron - 1400Pilot
You can try and retry www.bent-bike.com
they are a local bike wrecking and salvage yard. I just checked their inventory of listed motors but give them a call. Keep checking back. Search the net for motorcycle salvage stuff like that http://www.google.com/search?hl=en&q=motorcycle+salvage here is a google search
In Memory of Deron Harden - 1400 Pilot. You are missed. Last edited by Spok : 06-08-2005 at 08:02 PM. |
#7 (permalink) |
![]() Join Date: Mar 2005
I would pull it down and have a quick look. Possibly dropped a valve or stuck rocker or something. I am not familiar with that engine,but would pull at least the heads off ,so you can see what you need. If you are not mechanically inclined at all,find a general do it all type of back yard shop that will help you see whats the problem ,..without costing a ton to at least find out. You may only need to order 300 $ worth of parts?
04 MS 1640 Thunder 100 in kit/cams Race ported heads by "dynoray" Thunder air V&H Propipe PC3 |
#8 (permalink) |
the "fun old" guy
If you have a college nearby that has a machine shop you might be able to see if they will do your engine as a project and pay for parts. Just a thought.
#9 (permalink) |
Finally Got Into First Gear
Find a used engine if it's needed and there should be plenty available across the US. Tear it down (get someone to assist if you need help...maybe find a shade tree MC guy...) and find the problem first though. It might not need a "new motor". BTW, Kawasaki does not (generally) sell new motors...they sell parts=expensive. Also, low/no oil=bad. You might follow the trouble shooting advice in your MOM if you've got one...
Rule 1. Dealers are expensive. |
#10 (permalink) |
Top Gear Full Throttle
The Vulcan 750 normally lasts forever, that is why you don't see many at salvage yards. Plus it seems the 800A and 800B are more popular. Does it really cost 2-3000 thousand to rebuild a motor? Wow, on a 11 year old bike it might be worth it to look for a good used one.
2004 800 Vulcan Classic Cobra backrest Cobra floorboards Mustang Daytripper seat |
#11 (permalink) |
At this point you got nothing to lose but riding time....get a good shop manual and tear the thing apart!! I'd go nuts walking by it in the garage....I'd either have to take a sledge hammer to it or a wrench, and the wrench is probably the better idea!
#12 (permalink) |
Have you looked at www.bikebandit.com ? They also have schematics of all the parts online this way you could use it as an example as you pull it apart They also have cylinders etc. Check it out
'96 1500 classic, hard chrome pipes, mustang seat, Ness big sucker, whatever else I can add |
#13 (permalink) |
Old Enough to Ride Slower
Had a similar problem with my wife's vulcan 750. Found an engine at Steve's Cycle Salvage in Tifton. GA. 2000 miles on engine with exchange. $1000.00.
http://www.stevescyclesalvage.com/ ask for Alex he was very helpful.
2004 Vulcan 1500 Classic Phat II Risers Mustang Seat V & H Straight Shots Kuryakyn pegs |
#14 (permalink) | |
Wants better weather!
also if there is a vocational technical school they will very often do such projects kansas has alot of them that are state funded i don't know about other states |
#15 (permalink) | |
I miss you, Deron
![]() ![]() Join Date: Sep 2004
In memory of my friend Deron Harden. Life isn't going to be the same without him. |
#17 (permalink) |
![]() ![]() Join Date: Oct 2004
I agree with theo others. YOU could probably get a good deal on a used 2002 or 3000.
That quote seems awfully high. The voteceh schools are a great idea also. Good Luck!
Hers 2006 HD Deluxe (Nostalgia) Mine 2003 Vulcan 1500 Mean Streak-Traded |
