Vulcanorious
Hey guys
I have 800 2005 classic with 10500 miles on the m-cycle and still never done the valve checks, so decided to do this now as I was guilty of not doing so at the 6000 mark as mentioned in the manual. I did take the help of the valve adjustment manual and it has helped me a lot but then I have a lot of questions that I need some help from all who have done this before. I have the feeler gauge which has 2 values, the top value is .005 and the lower value is .127 & mm mentioned below that. This is how the feeler gauge shows me : .005 .127 mm I dont know which value to read. The PDF and the manual says that the value for Intake must be between .10~.15mm and for Exhaust .25~.30mm My questions are: 1) Which value do I read from the feeler gauge. 2) The intake valve is the valve that is near the Carburetor? 3) I removed the shims out and do now know which was where originally, I put them back to the positions and tried the feeler gauge and the .005 was going without much efforts on the intake side, I could not slide the guage on the other shim. These valve I assume are the intake side. 4) Do I have to turn the crankshaft again to check the Exhaust facing valve? 5) What is a Front Piston at TDC and Rear Piston at TDC? 6) Is it really necessary to change the shims? Thanks and looking forward to hear from anyone of your guru's out there Agnelo |
#2 (permalink) | |
JUST WANT TO CRUZ
the 800 was nice, but now an '05 HD fatboy |
Vulcanorious
If the feeler guages that I slide between the rocker arm and the shim are within the permissible value, do I need to make any shim changes?
Thanks for the answers. Once I access the mbike today I will post more questions. Agnelo |
#6 (permalink) |
Waiting out the WI winter
Do the valves really get off far enough to justify the time/effort? This seems like something I would do only to mess up something else in the process.
'99 Vulcan 800 Classic Don't drop what where? |
#7 (permalink) |
Cruising In Fourth Gear
I did my adjustment last week. The bike had 15500 and i dont know if they had been checked before. I had 5 of 8 super tight where .10 was NOT going to fit no way no how so yes it is important. It does not take a whole lot of time. I seen reports of 2 or 3 hours. I did mine just under 2 hours it helps when you have the shim kit at access. It isnt real hard to do. there are short cuts and once you do it you will see.the hardest part is the back cover i found it easier to take it out the throttle side. that took 10 - 15 minutes messing with that (trying to take it out on the clutch side) all and all it isnt bad.
vroc#26204 03 800A alot of custom stuff stock sucks |
#8 (permalink) | |
![]() Join Date: May 2008
I have noticed that with more miles on the engine valves do not need adjusted as frequently as they did when the engine was newer.
'95 800A (sold) '01 1500 Nomad "we are small and exposed, and probably moving too fast for our own good" -Dave Karlotski- |
#10 (permalink) |
Shim kit; ebay, $76... and PM Jeff for the PDF cause I forget where I found it.
#12 (permalink) | |
Keeper of Donkey
![]() Join Date: Jun 2008
Someone say valve adjustment on an 800?!
![]() Here's the PDF: 800 Valve Adjustment And here was my review after I did it! Quote:
Jeff - Ottawa, Ontario '99 Vulcan 800 Classic I WAS THERE! Day of Donkey August 8, 2009 Kansas March '09 M-o-M
#14 (permalink) |
Gilles
I just did mine on my 01 800B and no problem. You dont have to take half the bike apart for this. Remove gas tank, be careful how you set it down in regards to the fuel pet ****, the covers do come off without removing any coolant stuff, the valve covers will sit in place very nicely when you put it back together.
Good luck |
#15 (permalink) |
Vulcanorious
I just got the shims out of the rear engine, looks like they are not within the expected range, so I need some help to confirm this.
The rear engine has the intake side shims as follows : Clutch side ->> Clearance - .051 - Shim numbers are 50 Throttle side ->> Clearance - .076 - Shim numbers are 50 The Exhaust side shims are as follows: Clutch side ->> Clearance - .152 - Shim numbers are 35 Throttle side ->> Clearance - .152 - Shim numbers are 35 What value shims must I replace this with? When I try the feeler guage, can there be a negligible resistance or it should slide easily? Im not able to follow the exact method to reading the guage. Please help Agnelo |
#16 (permalink) |
Keeper of Donkey
Can you read this Agnelo? It's the shim sizing chart... one for inlet, one for exhaust...
#17 (permalink) |
Keeper of Donkey
Oh, and better slightly looks than slightly tight... they'll tighten over time on their own...
#19 (permalink) |
I'm not completely sure, given the measurements he has listed that I can read that chart either.
Will I be able to do this in two days? That's about all I'll have because I need to do this work at home. I think I need to read the pdf before I start asking more stupid questions. Actually the pdf does pretty well of explaining how to choose what to choose. I'm going to be pretty nervous when I tackle this one. (the example in this thread replaces both intake spacers with 2.45 and both exhaust spacers with 2.25?)
'99 Vulcan 800 Classic Don't drop what where? Last edited by Wiscblue : 06-02-2009 at 09:52 PM. |
#20 (permalink) |
Wants better weather!
I generally keep going up sizes until I find the guage that won't fit then I go by the previous size that did fit. A little resitance is fine, it's what you want to get an accurate reading, but if your having to force it in there then the guage is too big.
Tony 1998 VN800B |
| valve adjustment, more or less clearence as they wear. | jap thrasher | Main Lobby | 3 | 07-04-2008 07:46 PM |
| ***1600/1500 Classic/Nomad/Meanstreak/Maurader - Photo Contest*** | Spok | Kawasaki Cruisers | 170 | 12-12-2006 06:12 PM |
| Chain Adjustment Vulcan 800 | glarkin | Kawasaki Cruisers | 4 | 08-06-2006 07:21 PM |
| Vulcan 800 Classic Black or Wait for 900? | WalterRC | Kawasaki Cruisers | 29 | 10-28-2005 04:11 PM |
| Valve noise on the Vulcan 800 Classic | v800cruiser | Kawasaki Cruisers | 6 | 10-27-2005 11:09 PM |
