Old 07-03-2009   #1 (permalink)
VindianaJones
Poachers Place!
VindianaJones's Avatar
Cool Tight belt!
I guess I should have remembered this from the last time I had a tire replaced because it happened again. Both times by the same tech. We have a friend in town that has great prices on tires and really goes out of his way to make sure your taken care of when we take the bikes in. 2 years ago I got a tire changed by him and all was good except a noise in the belt area. I loosened it off a tad and it fixed the noise. This time was the same thing. But the noise was alot more noticable. If I came in off the highway, it was almost unbearable. When I looked at the belt and the adjuster marks it looked like one mark was a tad forward of the other. So I loosened the belt and adjusted the tire and sure enough. The belt moved to the center of the pully and its quiet as a churchmouse now.
To bad I spent a month listening to the noise before I decided I had had enough because it took less that 1/2 hour to fix.
Owell, I'll know for next time.
They shot you through the stupid forest, and you didn't miss a tree.
VindianaJones is offline   Reply With Quote
V2K Belt Noise Vulcan900 Kawasaki Cruisers 12 05-15-2009 01:09 PM
V2K belt noise-----gone!!!!! Lattimer Kawasaki Cruisers 15 02-11-2008 03:41 PM
V2K belt noise------fixed Lattimer Kawasaki Cruisers 13 06-05-2007 10:56 AM
Bought a 2006 2000 Classic LT, Need Advice oolddog Kawasaki Cruisers 22 01-27-2007 10:31 AM
