#21 (permalink) | |
Finally Got Into First Gear
Did you purge the air out of the system? Air pockets in a liquid pressurized system are vey bad. They are 'hot pockets' if you will, which means you over heated your engine. If it does not go through coolant you got very lucky. |
#22 (permalink) | |
Life Begins at 200 mph
Usually it involves filling up the radiator overfill and taking the radiator cap off. Then start the bike and watch for it to bubble. The level usually drops if you have air in the line. If you do, just keep topping it off till it doesn't drop anymore. Once you are done burping the system check the overfill container after a few minutes giving the system time to relax and see if you need to add any to that. again that is the general way to do it when the radiator cap is on the top of the radiator and not in a remote location like it seems yours is. It may be the same though. |
| Ways to drop your motorcycle | Freakinout | Main Lobby | 174 | 10-14-2009 02:58 AM |
| 250 too slow? | brooklynyte | Kawasaki Streetbikes/Sportbikes | 39 | 09-25-2008 08:22 PM |
